Question about Sharp AL 1631 Copier
I have H 3 flashing on my copier what can I do?
  • 2,632 Answers
Welcome to Fixya. H3 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time. It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the device by Press Program Key(P), Asterisks, Clear Key (C), Asterisk . when the stand by for simulation code appears type 14 to cancel the trouble code.
If the error persists then you may need new thermistors.
If you have questions please let me know. Thanks for using Fixya
Posted on Mar 26, 2011
  • Rofel Lantican
    Rofel Lantican Mar 26, 2011
    You can also try there press clr, exposure, clr, exposure, the display will blank, enter 14, press prnt button, then clr several times to get out and thats it.
Our Data light keeps flashing and the printer won't print. How do we get the data light to stop flashing so we can use our copier again with our computers?
Sounds like a bad print job stuck in a print spooler.
Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
Jan 15, 2013 | Sharp Mx-M450nb Digital Copier
When turn on the the copier, it flash "EO" green
An E0 is a fixing unit error. The fixing unit needs to be replaced.
Nov 17, 2010 | Canon PC-920 Black and White Copier
Toshiba 1360 copier has a red flashing 8 with arrows or zigzags can any one tell me what this means. the copier does not work while in this mode
When that is flashing your copier is jammed or thinks it is jammed, check the paper path for any sines of paper.
Jun 12, 2010 | Toshiba 1360 Black and White Copier
Copier flashes error
tell me your copier`s name and model
May 19, 2010 | Office Equipment & Supplies
What does flashing CH mean?
Flashing CH means that the developer unit is not installed inside the copier or its not well installed. Check and install properly.
Aug 24, 2009 | Sharp AL 1631 Copier
My canon NP6012 flashes E001. Copier flashes and
check also the thermal fuse or switch ,no ac supply is coming to fixing heater
Jul 10, 2009 | Canon Office Equipment & Supplies
What does C710 stand for?
GO ON LINE AND TYPE
KYOCERA COPYSTAR CS-1820 ERROR FLASHES C710
ENTER
GO ONLINE AND TYPE THE FOLLOWING INFORMATION
MANUFACTURE NAME,MAKE,MODEL SERVICE GUIDE AND DRIVERS
ROD
Feb 09, 2009 | Kyocera Copystar CS-1820 Black and White...
MY COPIER KEEP FLASHING A LIGHT OF PAPER YAM BUT THERE IS NOT ONE I THOUGHT IT WAS OUT OF INK SO I GOT A NEW BUT IT'S STILL FLASHING LIGHT
the copier have a paper jam on the left side on fixing unit or on right side .
or the copier have a paper sensor that does not move.
Dec 27, 2008 | Canon PC-940 Black and White Copier
L1 is flashing on my copier
Hello, Please check out the following website and see if you can find your error code:  http://www.copier-help.com/copier-help/
Hope this helps. Good luck
Dec 11, 2008 | Sharp AL-1217 Copier
Sharp AL 1631 Copier Logo
27 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
