When i turn on my laptop i get loading pbr for descriptor 2 done ntldr is missing on dell vostro 1700
  • 2,229 Answers
This is saying that the ntldr, which is a file necessary to start windows is missing.
You will need to follow one of these steps in the links, below:
Note, if you have Windows Vista or Windows 7, you'll need to boot from the Windows system disk and follow the prompts to repair Windows
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
http://www.fixya.com/support/r4501848-when_windows_xp_start_secondary_fix
Posted on Mar 26, 2011
My Dell says loading pbr descriptor
1)Try F8 safe mode and follow directions.
2) Insert installation disk and use repair option.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Apr 04, 2012 | Dell Computers & Internet
Screen says" Loading PBR for descriptor
And again and again and drives you up the wall.OK-boot sector is corrupted, or hard drive is going south.What you can try is system restore.On boot see which button is designated for that-usually f10 or f12.Start tapping that button and follow instructions. If that failed, the only option is to reinstall OS.If you have a lot of stuff that you want to save, install Windows in different folder, say WindowsA.All your stuff will be saved on the Hard drive-My Documents.Good luck and keep us posted.
Jun 14, 2011 | Computers & Internet
I have a message that says ..loading PBR for descriptor 2...done, when i turn my laptop on and thats as far as my laptop will go. It is a insprion 5160
PBR is the partition boot record and holds information regarding how to boot.
Dell systems use three partitions on the Hard disk - descriptor 1 is the Dell Utility partition, 2 is the XP partition, and 3 is the Dell Restore partition.
The error you are getting is due to a corrupt boot record.
Try this:
1- Start up the computer and click F12 to give you the boot-up options.
2- Insert Windows Installation/Recovery CD into CDROM, choose CDROM boot option and click enter.
3- Let the installation process continue until it prompts you "Press R to repair". . .this should then take you into the DOS mode.
4- Type in FIXBOOT and when prompted, press "Y" to start creating the new boot partition. If everything goes right, you should get a message saying the partition was corrupted and a new one was created successfully.
5- Remove the CD and reboot your system, everything SHOULD be ok now.
N.B: Dont try a FIXMBR or you'll loose you hidden dell partitions, meaning if you haven't backed it up onto DVD, you cant go back to the original factory settings if you ever need to.
Feb 28, 2011 | Dell Computers & Internet
Loading PBR for descriptor 2... MODEL DELL DV051
That is the boot loader message to boot to the NTFS Primary boot partition (Primary Boot Record for Descriptor 1 is the Utility partition)
Normally, this message flashes and the system boots, since it is not there is a failure in the boot process.
#1 run diags on the Hard Drive (CTRL+ALT+D at boot) and see if it passes
If it does
#2 Boot to you XP CD, press R for recovery console, and run the COMMAND CHKDSK /R see if the system will boot
If no go, go back to recovery console, try the command BOOTCFG /Rebuild then see if the system will boot
If That fails, try reinstalling Windows
If Diags Fail or all the above fail, replace the hard drive
Jun 24, 2010 | Dell Computers & Internet
Start up gets to "Loading PBR for descriptor 2... done"
I suspect that the viruses had infected some of the files that windows needed to boot up. The moment you ran the Mcafee, the scanning might have deleted or quarantined those files. That is the reason you're having this Loading PBR message because it is now trying to boot from the network and not from the hard drive. You will need to repair windows using the CDs that came with the computer (the Operating system CD/DVD) and run CHKDSK /R at the screen where it says 'repair your computer using the command prompt". If this does not work, chances are, you may need to reinstall windows and everything and that all information in your hard drive will be wiped out.
Jan 03, 2010 | Computers & Internet
I have a new Mini and I can not get the thing to work. When I turn the notebook on it has it?s boot up screen, then it goes blank and says this ?Loading PBR for descriptor 2...done? So how do I fix this?
I would recommend that you take it back to the store where you purchased it. Or call tech support if your unit is under warranty. CLICK HERE for a link to Dell Tech support. Good Luck with that!
Nov 10, 2009 | Dell Inspiron Mini 10 Notebook
When I first power up the notebook, it says " loading PBR for descriptor 2...done" pleaseadvise what to do next?
hii
This problem which you are facing is a hardware problem so you can go to vendor or you can visit our senoir technician at----http://tinyurl.com/nznbpm
Jun 20, 2009 | Dell Inspiron 2200 Notebook
Boot to the Diagnistics FN+POWER at boot, run hard drive diagnostics. The PBR Descriptor 2 message is part of the normal boot process (directing the boot loader to Primary Boot Recond 2, the C: Drive) but usually flashes on an off so fast most people never notice it. Since the boot process is not going past the re-direct it is indicative of a bad hdd (Since the re-image process crashed)
Most likely you are looking at a hard drive replacement.
Regardless you are going to need an XP CD (you'll have to reinstall windows or run recovery console at a minimum)
Apr 01, 2009 | Dell Inspiron 6400 Notebook
Loanding pbr for descriptor 2 done
hi there.. i'd really hate to say it but you have to reinstall your operating system.. honestly even if your're gonna try running chkdsk/p or /r it still no good it will just waste your time.
Mar 12, 2009 | Dell Computers & Internet
Computers & Internet Logo
135 people viewed this question
Alun Cox
David Payne
David Payne
