Question about 1998-2002 Park Avenue Door Lock & Alarm Interface
My 1994 buk parkave horn was going off on its own and now it just stays on so i unpluged it do you have a fix for that.
    New Friend:
How did you unplug it?
Posted on Dec 15, 2012
Fix a stuck horn on 1994 Camry XLE
There is a spring and a plastic clip behind the steering wheel pad/airbag. The plastic clip broke. Unplug the airbag or disconnect the battery before playing with the airbag. They can be nasty.
Feb 14, 2015 | 1994 Toyota Camry
Reassemble horn pressure switch in steering wheel
Ive had this issue and found its so much easier to go to the junk yard or dealer and get a new airbag/horn switch and just replace it. Very important. when changing these always unplug you battery or the air bag and go off and mess your day up.
Mar 22, 2014 | 1994 Buick Park Avenue
My 1994 ford f150 truck horn doesn't work ,I needto know how to fix it and what to do to rule out things ?
Find horn under hood,than unplug the wire on it ,take a long enough wire to reach battery and horn touch wire on horn where the plug gos in and the other end of wire on battery,if the horn dont sound than its the horn, go to harborfreight or parts store and buy a new one, ifr the horn does sound than take off panel on steering wheel,3 screws behid wheel and look for wire to be pluged in and check the grounding wire.
Feb 25, 2013 | Cars & Trucks
Horn randomly honks(very annoying while your trying to sleep) HELP!
its possible that the relay is the problem as most relays have a second power feed wire,if it shorts to the horn side of the relay it can blow the horn.doesn`t happen very often but it does happen.this could explain the horn blowing without the fuse in.you can get a door key made at a lock smith to solve that problem.
Nov 17, 2011 | 1994 Buick LeSabre
My horn keeps coming on and staying on witth out me doing anything how do i disconnect it or where would it be
check your wiring diagram it should have a fuse connected to it. try a new one and see if that fix's it. If not have the horn ground checked. you need a horn to pass inspection.
Feb 14, 2011 | 1994 Jeep Grand Cherokee
HORN DOES'NT WORK
Locate horn unplug it have a circuit test lest handy press horn if tester lights it will be the horn needs replacing.
Dec 20, 2010 | 1994 Pontiac Grand Am
1994 Buick LeSabre horn is stuck on. Unplugged
Replace air bag. Not servicable to repair horn. Special bits are used to remove it. Get a used one
Apr 06, 2010 | 1994 Buick LeSabre
1994 volvo won't go into park. had reverse lights and horn fixed
have the mechanic recheck his adjustments on the transmission range switch. the shifter shaft goes right throug the switch and it may have been adjusted or replaced when the backup lights were repaired
Apr 01, 2010 | 1994 Volvo 940
No horn in '94 Jeep Grand Cherokee
go to the horn under your hood, check it for any thing wrong, then follow the power wire and follow it back to your steering wheal. this is where your problem is you just have to find out where the short is. and fix it.
tepfy
Apr 04, 2009 | 1994 Jeep Grand Cherokee
1998-2002  Park Avenue Door Lock & Alarm Interface Logo
93 people viewed this question
Top Buick Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jeffrey Turcotte
Jeffrey Turcotte
mike
Are you a Buick Vehicle Part and Accessory Expert? Answer questions, earn points and help others
