I bought a Honeywell air purifier HPA-051. Pre-filter was in a plastic bag at the bottom of the box. The instruction manual is not very clear about the installation of it. I don't know where it should go. Should I install it inside the rear grille? The pre-filter has a black side and kind of a grey side. Which side should be facing the true HEPA filter? Thanks a lot for your help! Andrea
    Problem Solver:
  • 19 Answers
They should have an etched in arrow of direction of flow
Posted on Aug 02, 2017
RepairUSA
  • 50 Answers
SOURCE: Installing
Turn the curtain and bracket so when mounted to the ac the window will close behind it. Hope this helps. Thx RepairUSA
Posted on Aug 26, 2007
  • 86 Answers
SOURCE: lg ptac heat pump/ac 12k btu 230v stamped allum grille installation
1. open grill from out door box.
2 fix outer box where u want.
3 put a/c inside the out box
4 make proper wiring.
on the unit
Posted on Mar 28, 2008
jerryg50
  • 1689 Answers
SOURCE: how to find the carbon filter to change it and how we should clean the hepa filter on our
You should contact Honeywell to find out their parts rep for your area. I don't think you will find these parts in the regular hardware store.
Use Google to find the Honeywell home page, and work from there.
Jerry G.
Posted on Apr 27, 2008
chillmaster
  • 104 Answers
SOURCE: Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
AUX-white
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
170-7
190-1
200-0
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Posted on Jun 18, 2008
CMV9
  • 594 Answers
SOURCE: want to replace HEPA post filter
http://www.dyson.com/customercare/manuals/us/dc07_manual_us2007.pdf
here is the link to your owners manual. scroll down to page 6 it shows you the filter to clean and how to take it aprt.
Posted on Jan 08, 2009
How do I access the filter on a honeywell enviracaire 10500 air purifier
Hello, this is Ava with Think Crucial.
You may find your online instructional manual on how you can access the filter cage of your Honeywell model by clicking the link below.
Honeywell enviracaire 10500 Series Owner Manual Page 7
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 13, 2013 | Honeywell Enviracaire 10500 Air Purifier
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
How do you change the filter? My in-laws have lost the instructions for their purifier.
You have a Honeywell air filter. Turn it over and there is a big handle which is a screw in the middle. Unscrew it and then lift the entire unit up without the outside screen protection. The filter will have a black pre-filter attached by velcro. Remove it, take outside put on the grass and hose out against the flow of air. (squirt from the inside out to remove stuff). Then use vacuum to blow the filter from inside to the out. Then vacuum the filter from outside in. Let the pre-filter dry. re-install in reverse. If there is a warning light, run on full, then push the warning reset for 10 seconds or more to turn it off.
Mar 01, 2011 | Duracraft DA5010 Air Purifier
How to change the flter
Turn off the unit and unplug it. Turn the air purifier on it's side and unscrew the locking mechanism (turn counter-clockwise) on the base of the unit. Remove the base assembly from the unit. Remove the filter assembly and find the seam of the pre-filter. Carefully separate the fastener and then remove the pre-filter from the HEPA filter.
Discard the filter(s) being replaced. Then remove the new filter from the packaging and discard the packaging and plastic. Carefully wrap the pre-filter around the HEPA filter so that the ends meet. Fasten the ends together with the fastener.
Place the filter assembly in the air purifier and reattach the base. Then tighten the locking mechanism. Turn the unit right side up, plug it in and turn it on.
You can find a pdf of the manual here: http://www.honeywellpurifiers.com/product/0-90271-50150-4.html .
I hope this helps.
Oct 03, 2010 | Honeywell 50150 Air Purifier
I want to take the 17440 air purifier apart to see why it won't start.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 30, 2010 | Honeywell 17000 Air Purifier
Unable to locate owner's manual for Honeywell
Go to honeywell.com
Mar 25, 2010 | Honeywell QuietClean HFD-010 Air Purifier
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
