Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Loud bang during spin
My washer was spinning, and I heard a very loud bang, and the washer quit. No power, door is locked, no signs of life. What happened?
Unplug it and plug it back in after a min. Try to put it threw a rinse spin cycle. Delicate option has a shorter rinse spin time.
See if it suds up, when you hear it trying to drain lift up the drain hose to the wall. It is the gray tube that has the elbow bend, might (should) be hooked to wall. If it isn't moving a good amount of water the machine isn't draining.
Posted on Aug 26, 2008
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
When washer spins it makes a loud banging noise, washer is a front load kenmore
Thanks for choosing FixYa and welcome. Anytime loud noises are heard, it can almost always be traced back to the drive motor. That is what controls the spinning. Check that and the spin bearing. One of these two are probably your problem. Make sure the washer is level though. Check the suspension.
Apr 30, 2011 | Kenmore Washing Machines
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
The washer shakes uncontrollably during the spin cycle also a loud banging noise is heard during the spin cycle.....
If front load check the inner drum If it is loose at all you have a lot of problem . Very expensive.
Nov 17, 2010 | GE Washing Machines
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My kenmore elite top loader has a loud banging noise when spinning
Disconnect power to the washer then tape the lid closed. Lay the washer carefully on its front panel on a padded surface then check the four suspension spring/rod assembly. Make sure the suspension doors are properly attached to the outer tub to prevent an off balance situation that may lead to the banging of the basket to the outer tub during the spin cycle. Also ensure the machine is balanced and properly or evenly seated on the floor.
May 07, 2010 | Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Washing Machines Logo
270 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
