Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Blinking light did u ever get the blinking light fixed on your mitsubishi television. I am experiencing the same problem.
  • 927 Answers
Good Day, moreb1;
If you can solder and etc try the following or call a factory service dealer to give you an estimate:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). SEE< Good Luck, big IRISH.
Posted on Aug 07, 2008
SOURCE:
Click power on the light flashes on one then off nothing else
Yes......w\they call this the blink of death for these sets. It will most like ly need a DM board which may exceed practical expense or may not be available. In some instances an experienced shop will replace the capcitors in the assembly and fix it....other times it will need the assembly
Jun 02, 2010 | Mitsubishi VS-45607 45" Rear Projection...
My Mitsubishi tv power light keeps blinking
have a 55 inch Mitsubishi TV.. the green power light keeps blinking.. is there anything I can do myself?.. or I have to have someone to get it fix?
Nov 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi TV Model VS45609 Blinking Green Light
I have a Mitsubishi VS 45609 tv. I turned it off at midnight and tried to turn it back on the next morning and nothing happens. Can you help?
Nov 03, 2009 | Televison & Video
Mitsubishi TV WD-62527 will not turn on
Hi there, this is most commonly known as power board failure in the industry. the capacitors are blown. if you are experienced in inspecting circuit boards this will be helpful. you will have to disassemble and pull the power board and preform a break point test. the bown capacitors are easily picked out. they will be swollen and discolored. If you are not comfortable with disassembling this set, i suggest a service call. just tell the tech you are experiencing a power board failure.
Mar 07, 2009 | Mitsubishi WD-62827 62" Television
Video Instructions for repairing TV blinking light WS-55589:
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
I repaired mine using this and I am certainly not "handy". Good luck!
Jan 26, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Blinking timmer light mitsubishi 1080
Video instructions for repairing Mitsubishi WS-55859 HDTV:
You can find the parts (capacators) at Radio Shack for appx. $2/each.
Jan 18, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi 55859 Blinking Green Light
Dec 27, 2008 | Mitsubishi WS-55809 55" Rear Projection...
57" Mitsubishi won't power on, blinks green timer light
It is a common failure of the 57" Mits. DLP. The problem is a defective thermistor and is covered by Mits. Contact a local repair shop and they will fix it free (parts & labor)
Sep 04, 2008 | Mitsubishi WD-57731 57" Projection HDTV
[email protected]
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Oct 14, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
