Question about ViewSonic PJ550 Multimedia Projector
When i turn on the projector, it begins to start up but then the red temp light comes on and the projector shuts off. I have replaced the bulb, but it still does this.
  • andrew_ro354 Mar 28, 2011
    I have cleaned the filter, and yes it sounds like the fans all come on. It only starts up for a few short seconds and then the red light comes on and it shuts off immediately.
  • 442 Answers
Have you cleaned out the air filter recently. Do all the fans come on when it starts up for the short period that it's on?
Posted on Mar 28, 2011
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
Epson Powerlite 830p lamp light comes on and turns off projector with new bulb.
Clean the fans and filters. Check the lamp door switch is making contact.
Jan 27, 2018 | Epson PowerLite 830p Multimedia Projector
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
When I hit the start button on my NP 115 it begins to sound like the fan labors and pulses until it shuts down and the red light blinks in a series of 6 blinks. It also has a very hit frequency squeak that...
after 5 minute image go out n power indicator steady light orange n status indicator red light blikns in a series of 6 blinks. in the manual book said lamp error.. what mind "lamp error". please help me.
Jul 28, 2011 | NEC NP115 DLP Projector
My TLP680U projector shuts off after 1o minutes of operation.
toshiba is not one of the most rliable makes im afraidi have seen this fault before and it turned out to be the bulb which i had recentley replaced and this was apparentley the wrong one and gave the same sort of results.
Feb 25, 2009 | Toshiba TLP 680 Multimedia Projector
Projector shuts down after turned on and both red lights blink
this model is prone to over heat. look near the lamp for the temp sensor it is most likely bad
Nov 30, 2008 | BenQ PE7700 Multimedia Projector
Temp fault
check all the internal fans, if even one does not start, the projector will soon shut down!
every fan has three wires, one is the stop signal, that should stay "low" in most models.
this wire might be white or yellow, the red is + supply/blue or black is -supply(or gnd).
Sep 17, 2008 | Office Equipment & Supplies
Flashing lights?
Hi there
This sounds like a faulty Powersupply.
Before replacing it , try replacing the fuse on the board first.
Apr 14, 2008 | Fujitsu LPF 7200 Multimedia Projector
ViewSonic PJ550 Multimedia Projector Logo
280 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
