Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
It died and won't switch on again, the roller had carpet threads around it, can it have burnt out? The plug fuse is ok, there wouldn't be an internal one would there?
    Genius:
  • 1,739 Answers
The User Guide for the DC07 can be found here:
http://media.dyson.com/downloads/caen/floorcare/Manuals/dc07_opmanual_caen.pdf
Your machine is fitted with a belt protection system. If any item becomes caught in the brushbar (e.g. rug fringe), you will hear a loud 'ratchet' warning noise indicating an obstruction.
To rectify, turn the machine off, disconnect from the electrical outlet and clear any obstruction. Lay the machine on its front.
Undo the colored soleplate fasteners using a coin and remove the soleplate.
Clear the brushbar obstruction, carefully cutting away any threads with a pair of scissors. Replace the soleplate and tighten.
Press the brushbar reset button on the back of the cleaner head. See here for illustration:
http://www.english.dysoncanada.ca/support/help.asp?product=DC07-SY-HEPA&article=1133
Should any part of the machine become blocked, the motor may also overheat and stop due to the thermal cut-off being triggered. Disconnect from electrical outlet and let the machine cool down for at least 30 minutes before clearing the blockage. You may need to check for blockages in other parts of the machine.
Posted on Mar 26, 2011
What is a good vacuum cleaner for cat hair, kitty litter, dust, and people hair?
I would by this vacuum it one of the best buys around I fix vacuums for a living this is a good vacuum FB MMPWCF4 Fuller Brush Mighty Maid upright Vacuum with Carpet Floor Switch
Dec 22, 2015 | Vacuums
Carpet broom won't start
Check the belt and the end bearings are free by hand, (electric off plug out) if not free remove plate to access roller/brush, remove clear any obstruction (Hair/string/thread) replace and test. ensure you site belt back on to spindle and roller/brush correctly.
Aug 25, 2014 | Electrolux Epic 6500 Vacuum
Burnt rubber smell when vacuuming
This could be a few things:
A. If your model has a floor selector switch (Bare floor/tools - Carpet) your clutch could be worn. (there is a rubber clutch pad between your cam and roller shell) - Fix would be to replace the clutch pad and belt.
B. If you don't have one of the above models, your belt could be stretched. The belt slipping could cause a rubber burning smell. Fix - Change belt.
C. Have you got any new carpet you are vacuuming or have you moved? Some of the newer style frieze carpets can cause burning rubber smell. The fibers of the carpet are longer and cause the brush to slow down causing the belt to burn. (Imagine brushing long hair with a thick brush, the hair easily gets tangled in the brush, same effect with this carpet.) Some of the newer rugs can do this as well. Some newer carpets with the thicker felt backing and/or the "pet padding" under the carpet can too. it doesn't allow enough air to flow through causing the cleaner head to seal itself to the carpet causing a burning smell. The fix is Move to another home, replace your carpets or replace your vacuum. The vacuum is the cheaper option but be cautious as most vacuums now do this with these carpets. We have had really good response from customers using the Simplicity Tandem Air models, (Synchrony and Synergy models.)
Hope this helps, if you need to talk further feel free to contact me.
Tim
TheVacCenter.com
Mar 13, 2013 | Simplicity Vacuums
Carpet brush not rotating
Did you check the drive belt for the roller? If not do so, the smell was the belt drive burning up.
Jan 16, 2012 | Kenmore Vacuums
The brush roller is not rotating on my Kenmore Whispertone. It will pick up on floor surfaces. Help!
Be sure that there are no fibers wound around the roller or lodged in the wheel well of the brush roller. That is usually the cause of a brush roller not rotating. You might need to use scissors to clip the fibers and then pull them from the roller. The fibers might range from human and pet hair to carpet fibers, threads, string, yarn, embroidery floss. They wind around the roller and eventually "tighten up" so that the rotator will not move. I have found that, depending on my current craft project, I may have quilting thread, knitting yarn, embroidery floss, or other such goodies wrapped around the roller. When our daughters were at home we would have long, beautiful blonde hair tangled in the roller. I hope this helps.
Nov 10, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
Hoover wind tunnel, brushes are not spinning. Belt seems loose but maybe that is normal.
The belt (one around the roller) will only engage the roller upon 2 conditions. the carpet switch needs to be in carpet and the machine needs to be tilted back. The other belt, may appear to be on, but can be stretched and also cause this issue, the recommended time to replace the belts are 9 - 12 months under normal use.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 24, 2009 | Vacuums
Eureka 4870: Brush roller turns even in hose setting.
You either have the wrong size belt, most likely too small, or you have installed a new belt incorrectly. When you open the cover on the bottom of your vac, you will see the pulley that moves as you flip the switch from floors to carpet. The belt does not go around this pulley. When activated(carpet) the pulley puts tension on the belt causing it to turn the roller. When switched back to hard floors, the belt looses tension allowing motor to cause suction but disabling roller. Also, the dial on top of vac is only to direct suction, not for disabling roller
Jun 21, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
M1300 i dirt devil brushes wont roll
Ok I would say the belt burnt into if you can turn it on and the motor runs it is the belt . I would pull it apart and replace the belt.
Feb 25, 2009 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Hi, I was using, and it stopped suddenly. what does it mean? Burnt out?
no not really if something is keeping the brush rolle from turning then the motor guard will keep it fron running .check if the brush roller can be turned by hand and freely if its real hard to turn then the roller bearings are bad or there are carpet strands tide up around the ends of the roller keeping it from turning correctly.feel free to call me if you need help.i don't charge i just like helping people and saving them money in these rough times.314-628-9153
Dec 06, 2008 | Kenmore 35912 / 35913 Progressive Upright...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
54 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
