Question about Avanti WCR5103SS Stainless Steel Wine Cooler
HELP with AVANTI WC 600CL not cooling I have an avati wc600clWC601cl wine cooler that is not cooling, compresor is runing but get really hot, what you think tha the compresor die or only run out of freon, this cooler use 134a and i thinking about fixing because is 54 bottles and new ones runs around $500.00 is almost new condition eve have several years. probably worth invest in replace the compresor if that was the case. Thanks, Joe
5 Suggested Answers
  • 1314 Answers
SOURCE: Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Posted on Jan 01, 2008
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
SOURCE: Avanti 12 bottle wine cooler...switch
CHANGE THE CAPACITORS ON THE POWER SUPPLY (TO SAME VALUES) AND REMOVE THE JUMPER (CATODE OF THE BRIDGE TO THE CAPACITOR DOUBLE VOLTAGE)
Posted on Apr 16, 2009
  • 93 Answers
SOURCE: Avanti EWC16B (wine cooler) got fried by power surge
A lot of time during storms the control boards in appliances get messed up. Try unplugging it and plugging it back in after about 20 seconds. A lot of times that will reset the controls.....if they did not get fried.
Posted on Sep 12, 2009
Testimonial: "I enjoyed the detailed explanation. The fuse was indeed blown, but the diode probably as well. But can anything else be blown??"
My avanti wine chiller mod ewc 16 b serial n.0800854 stop cooling what can i do ?
I've added a link for an Avanti ewcb,
http://www.retrevo.com/support/Avanti-EWC16B-Refrigerators-manual/id/867bh235/t/2/. There you can find a complete manual on the product which will help you to locate where the problem is coming from. hope I've helped!
Oct 24, 2012 | Avanti EWC16B Thermoelectric Wine Cooler...
My Avanit WC54 wine cooler turns on, however it does not cool. Every few minutes it makes a clicking sound
if you are handy go to a refrigeration supply hoese and buy a 3-1 pack remove the wires from the compressor let it cool if hot and hook to 120 volts wiring it shows you on the package..........luck
Jun 16, 2011 | Avanti WC54 Wine Cooler
My Avanti WC 601 is not cooling. The compressor is not on, however I was able to knock it and it did go on for a few minutes.
replace the rtc overload contactor located on the compressors body the relay is weak and not holding anymore,remove the spring wire that holds the overload and capacitor unplug the overload from the compressor and reverse procedure to install
Jan 16, 2010 | Avanti WC601CL Wine Cooler
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
Oil appears to be leaking from my Avanti Wine Chiller
Is it cooling ok?Where did you find the oil? If is not cooling and you see an oil spot inside or outside where the compresor is that means there's a refrigerant leak.
May 01, 2009 | Avanti WC3200BG Wine Cooler
Avanti Wine Refrigeraator
thanks for the question i think the problem is that its under the counter no air flow to cool the coils try it not under counter thanks the appliance doc
Sep 24, 2008 | Danby DWC283BLS Wine Cooler
Magic Chef MCWC30MCG not getting cold anymore?
Replace PTC Starter and that is it. You can also try to open and clean contacts, I did and it worked.
May 28, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
My cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
May 27, 2008 | Avanti EWC28 Wine Cooler
Dec 31, 2007 | Avanti EWC28 Wine Cooler
Avanti WCR5103SS Stainless Steel Wine Cooler Logo
93 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
