Question about Nintendo Wii Console
WIIHAD GEEK SQUAD CONNECT OUR WIRELESS INTERNET SERVECT TO HOME COMPUTER, A LAP TOP AND WII. HE ALSO HOOKED UP FAST INTERNET AND TOLD ME TO RUN A DISC AT A LATER DATE. I RAN THE WRONG DISC AND WIPED OUT ALL INTERNET CONNECTIONS. A WEEK LATER THE COMPUTERS HAVE CORRECTED THEM SELVES AND ARE BACK ON LINE, BUT THE WII ISN"T. THE GEEK REP COULDN'T GET IT BACK OVER THE PHONE AND SUGGESTED I CONNECT UP WITH YOU. CAN YOU HELP? PLEASE
  • Nintendo Master
  • 20,318 Answers
If you think you are talking here with Nintendo, you aren't. I can't imagine a technician telling you to come to Fixya. We are a peer to peer, self help website, people just like you and I helping each other because we can.
Contact Nintendo direct
Wii com
Posted on Jul 02, 2017
5 Suggested Answers
  • 27 Answers
SOURCE: Wifi connection
maybe you had it in to long just let cool down for a few day because you had it in for a few weeks
hope this helps
Posted on Jan 23, 2008
kpenguin
  • 35 Answers
SOURCE: Wii wireless connection
On your computer Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1
Look for the SSID and write it down.
Also write down the type of encryption you are using. WAP, WEP, or none.
Also write down the security Passphrase.
Also you will need the IP address, in Windows click on Start, Run and enter 'cmd" in the run box.
At the command line type "ipconfig" and record the IP address
On the wii, You should be able to have the wii look for a Wireless Access Point. If that does not work try the Manual Setup in the Internet Connections menu.
Enter SSID
Enter Type of Encryption.
Enter Security Passphrase
Enter IP address
MTU value is not required. Nintendo recommends 1500 if you are having issues.
http://www.nintendo.com/consumer/systems/wii/en_na/connectingOnline.jsp?entryId=wRouter
Posted on Mar 10, 2008
  • 12 Answers
SOURCE: can not get internet connection....my wireless
http://www.wiichat.com/nintendo-wii-online/5465-wifi-error-51330-a.html
Posted on Nov 16, 2009
  • 22 Answers
SOURCE: We moved. When Geek Squad hooked up our
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aaaabb10
Posted on Jan 13, 2010
I had Best Buy geek squad set up my computer and wirelless connection and now when I try to set up my Kindle they say I need a wireless password which I do not have. I will need to have everything...
The Geek Squad set a password inside your router for the wireless network,
and set an 'SSID' value for the name of your wireless network.
They should have told you what the password and SSID are.
Dec 20, 2010 | Computers & Internet
FPD2275W (Black) LCD Monitor: I took my CPU to geek squad and told them it would...
Did you try the monitor with other PC? All the pins on the video cable OK?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed GATEWAY monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | Gateway FPD2275W LCD Monitor
How can I connect my alltel internet card to my wii system
Unfortunately you cannot insert your USB modem into your Wii and have it recognized. Your Wii does not have the ability to operate plug and play devices in the way that your lap top does. The Wii needs to be hooked up to a LAN (local area network) via a wireless G connection from a wireless router or wireless capable modem, or hard wired to a modem or router with an ethernet cable (looks like a big phone wire).
There is a way to share your lap tops internet connection using an ethernet switch (depending on your operating system). If this is an option that you wish to explore and you have the necessary hardware, re-post asking how to set up a shared internet connection using a computer as a residential gateway. Depending on your operating system this can be done quite easily. You will need a computer with an internet connection (which you have), a 10/100 Ethernet switch, and two Ethernet cables. A switch is relatively inexpensive and the wires are as well.
I hope that this helps you with your problem.
Good Luck!
Jul 28, 2009 | Nintendo Wii Console
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Wireless connection
When you get signal strength excellent than at that time goto command prompt by typing cmd in run window and than type the following command at prompt c:\ipconfig / all and this command will show you the status of your all wireless and NIC card ip address. So pls check that wheather u are getting the ip address in the wireless connection or not. and if you are not getting it than
1> first of all connect the wireless router physically by lan cable and than open it in browser by typing ip address of it and than enable the dhcp in it with proper ip address range of you local lan. and than save and restart the router. This might resolve your problem and feel free if any other query.
Jan 10, 2009 | Linksys Wireless-G WRT54G Router
Hi. I have a Belkin Wireless G Plus MIMO Router, which has been fine to connect my laptop to the internet (although seems slow sometimes). I just got a Wii, but this wont connect to the internet. The Wii...
Check for the wireless encryption settings associated with this. If you're trying to join a network with "Open" settings to a encrypted network it won't work very well.
Nov 17, 2017 | Belkin Wireless-G Plus MIMO Router with...
Connection problem with wireless computer.
try connecting your dsl modem to the router and connect another cable between router and the computer
make a wired connection
try browsing
if you can let me know we can connect to your system remotely and can fix any issue you r facing with it
Jun 07, 2008 | HP Pavilion dv6000z Notebook
Nintendo Wii Console Logo
37 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
