Question about HP K8600 InkJet Printer
I AM GETTING AN INK DOOR OPEN LIGHT ON MY PRINTER FRONT AND THE DOOR IS CLOSED ( HP K8600.)
  • 122 Answers
Hello, Please can you check the little lid presses when you open the door if it has problem. you can pull it a little to check on it, but it must be out of the light before you can try it.
Posted on Mar 26, 2011
How to reset printer
insure that the rear door is closed well
Nov 17, 2014 | HP OfficeJet Pro K8600 Printer
How to reset HP Ink Levels Printer hp officejet pro k8600
the only way to reset ink levels is to replace the cartridge(s). If you're refilling, you need a second set of cartridges and use them in rotation with the first set.
Aug 29, 2014 | HP OfficeJet Pro K8600 Printer
Hp k8600: feeding paper only but not printing.
are you using comaptible inks if so try changing for another or go back to originals if this is the case
Mar 07, 2011 | HP OfficeJet Pro K8600 Printer
My HP Officejet Pro K8600 won't print black. I have changed the printhead, the cartridge. I have soaked the printhead, I have shaken head. I am getting yellow ink out but no black. I have run every...
Materials needed: New empty syringe (big one) Gloves (to protect your hands fromink) Alcohol Paper tissue (to clean the excessink) Empty Plastic bottle (Here you putthe ink from the syringe) Important: Ensure that you have put new blackink cartridge to K8600. Ensure that the printhead arerecognized by the printer or no light alarms. Instruction: Press the Power button to turn onthe printer. Test print in microsoft excel with4 color black/yellow and cyan/magenta. If black only is missing means youhave clogged problem from the host. Wear your globes, prepare thematerials needed. Open the top cover. Press and hold the Resume buttonuntil the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left sideof the printer. If the carriage does not move to the left automatically, turnthe printer off and back on and then try holding down the Resume button again.The printhead can be damaged if the carriage is not all the way to the left forinstallation. Lift the printhead latch. Lift the handle of a printhead anduse it to pull the printhead black/yellow out of its slot. Put printhead in thepaper tissue upward. Your printer are still ON becarefull not to touch the flex copper circuit. Get your syringe, use this to pullthe ink from the nozzle cap ( see link picture) After the done the syringe method,Insert the printhead black/yellow into its color-coded slot. Press down firmly on the printheaduntil it snaps into place. Pull the printhead latch all theway forward, and then press down until the latch engages. Close the cover. The printer should align theprintheads automatically in a few minutes, printing an alignment page. Print a test with black color only,If it does not print, try to change the Printhead. This is the only solution I foundin my HP k8600 black ink problem._579.jpg
Jan 24, 2011 | HP OfficeJet Pro K8600 Printer
Hi, the magenta ink won't work on my printer hp office jet pro k8600. I have replaced it with a new one and even though is shows that it's full on the ink levels it won't print it at all, I have tried all...
Materials needed: New empty syringe (big one) Gloves (to protect your hands fromink) Alcohol Paper tissue (to clean the excessink) Empty Plastic bottle (Here you putthe ink from the syringe) Important: Ensure that you have put new Magentaink cartridge to HP K8600. Ensure that the printhead arerecognized by the printer or no light alarms. Instruction: Press the Power button to turn onthe printer. Test print in microsoft excel with4 color black/yellow and cyan/magenta. If magenta only is missing means youhave clogged problem from the host. Wear your globes, prepare thematerials needed. Open the top cover. Press and hold the Resume buttonuntil the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left sideof the printer. If the carriage does not move to the left automatically, turnthe printer off and back on and then try holding down the Resume button again.The printhead can be damaged if the carriage is not all the way to the left forinstallation. Lift the printhead latch. Lift the handle of a printhead anduse it to pull the printhead magenta/cyan out of its slot. Put printhead in thepaper tissue upward. Your printer are still ON becarefull not to touch the flex copper circuit. Get your syringe, use this to pullthe ink from the nozzle cap ( see link picture) After the done the syringe method,Insert the printhead magenta/cyan into its color-coded slot. Press down firmly on the printheaduntil it snaps into place. Pull the printhead latch all theway forward, and then press down until the latch engages. Close the cover. The printer should align theprintheads automatically in a few minutes, printing an alignment page. Print a test with magenta coloronly, If it does not print, try to change the Printhead. This is the only solution I foundin my HP k8600 printing problem.christan_11_1.jpg
Jan 14, 2011 | HP OfficeJet Pro K8600 Printer
Won't print, orange triangle with exclamation point
This triangle light blinking indicates that a door is open. Open the front access door completely. Close the front access door completely. Open the rear door and close it.
If this didn't fix it refer to this guide for all errors you get with this printer from HP website.
Dec 16, 2010 | HP LaserJet CP1215 Color Printer
For some reason my HP Officeject Pro K8600 is reading empty yellow ink cartridge even after I replace it. I have replaced the cartridge several times with a new cartridge but it still won't work. Why? ...
The mount that holds the spring for the yellow ink cartridge pump arm in the service station is probably broken. You will have to replace the ink-service station.
Sep 15, 2009 | HP OfficeJet Pro K8600 Printer
HP C7280 Printer not priting wirelessly.
Solution Replace the indicated ink cartridge(s), or press OK on the control panel to continue. HP recommends the use of genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help produce great results, time after time.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage due to the use of non-HP ink will not be covered under warranty. Follow these steps to replace the depleted HP ink cartridge(s). Step one: Replace the indicated cartridge(s)
  1. Make sure the HP All-in-One is turned on.
    NOTE: The Attention light blinks when the product is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the door locks into place. Figure 1: Opening the access door c01079714.jpg
  3. Squeeze the bottom of the latch below the ink cartridge to replace, and then lift the latch.
    • To replace the black ink cartridge, lift the latch on the far left.
    • To replace one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    Figure 2: Lifting the latch c01079715.jpg 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
  4. Pull the ink cartridge towards you out of its slot to remove it. Figure 3: Removing the ink cartridge c01079716.jpg
  5. Remove the new ink cartridge from its packaging.
  6. Holding the new ink cartridge by the handle, push the ink cartridge into the empty slot. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage. Figure 4: Inserting the new cartridge c01079717.jpg
  8. Close the access door. Figure 5: Closing the access door c01079719.jpg
Step two: Align the new ink cartridge(s)
  1. Make sure paper is loaded in the input tray, and then press the OK button. The HP All-in-One prints the alignment page, aligns the printhead, and initializes the ink cartridges. This takes approximately 5 minutes. CAUTION: Do not disconnect or turn off the HP All-in-One during this time. You may hear the HP All-in-One making noises.
  2. Check the display for status, and then press the OK button. Recycle or discard the alignment page.
Cause The original HP ink in the indicated ink cartridge(s) has been depleted.
May 24, 2009 | HP Photosmart C7280 Laser Printer
All lights are blinking, printer doesn't work. What does this mean?
This problem occurs for two reasons: the front panel cover was not installed or the ink cartridge access door was not closed before plugging in the all-in-one.
The front panel overlay must be correctly installed before the power cord is plugged in. Follow the steps below to correct the problem:
Disconnect the power cord.
Lift the scanner4.gif lid and carefully line up and install the front panel overlay.
Plug the power cord in.
let me know if this solves your problem wendy.
Dec 18, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP K8600 InkJet Printer Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
