Question about Comet GXD2527G Pressure Washer Pump
I have a Comet AXD 2325 pump which is bolted up a a 5 hp honda Would a 2725 g comet pump work. a bit big in GPM
3 Suggested Answers
lilmikew99
  • 122 Answers
SOURCE: Oil for Comet pump
aftermarket oil will be fine just use same grade of oil,all manufacturers want that extra kick,
Posted on May 12, 2009
  • 760 Answers
SOURCE: what type of oil goes in a comet axd 3020 pressure
You should use what the pump manufacturer recommends. Typically a 30wt non-detergent (non foaming) oil. Do not over fill. If there is a sight glass half way is normal. Or if it has a dip stick follow the mark there.
Here is a great link for pressure washer parts and info
This link goes right to oil page:
http://pressure-washer-parts.com/shopdisplayproducts.asp?Search=Yes
Posted on Jul 14, 2010
What are the required motor specs for an AXD 3020
Found this ... hope it helps ...
" 87025760 Comet AXD3020 replacement pump 2000 psi @3.0 gpm, 3/4" shaft. Fits most 7hp and below engines with horizontal mountings."
Otherwise maybe these guys can advise.. Good Luck! https://www.rjbowers.com/xcart/Comet-AXD3020-Replacement-Pump-87025760.html
Jun 27, 2018 | Garden
Who has axd 3020 oil in isle of man
30 weight non detergent works in most pressure washer pumps. available at most auto parts stores.
Jan 08, 2014 | Comet GXD2527G Pressure Washer Pump
Comet axd 3020 will not build pressure
junk axial wobble plate pump. Usually axial pumps are not worth the time to try to fix them. This one has a 5 year warranty , so they think they have a pretty good one. ( I would never buy one) If you want to try to fix it, I would check the check valves first. Take them out and see if some are broken or not sealing properly. There is a valve kit available.
The other likely problem is your unloader valve. If the seal is shot or the valve stuck open the pump will not build pressure.
parts diagram http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/axd-PUMP%20BREAKDOWN.pdf
Oct 31, 2013 | Comet Garden
Comet pressure washer is pulsating
check your check valves.
or one of the wobble plate pistons is not working right ( broken, broken spring etc)
Aug 17, 2013 | Comet AXD 3020 G Pressure Washer Pump
My GDX 2525 will not pressurize water. I have tried adjusting the calibration knob on to without success.
It could be that the linkage between the engine and pump is broken. Try the key on the drive shaft. This is a piece of metal that locks the pump shaft and the engine shaft. If it still pumps water the problem probably lies elsewhere.
Jun 08, 2011 | Comet Pump Pressure Washer Pump 2.5 Gpm,...
What type of oil goes in a comet axd 3020 pressure washer pump?
Jul 14, 2010 | Comet GXD2527G Pressure Washer Pump
Oil for Comet pump
May 12, 2009 | Comet GXD2527G Pressure Washer Pump
Comet GXD2527G Pressure Washer Pump Logo
408 people viewed this question
Top Comet Garden Experts
michael
michael
Joseph Hoffmann
John Trevino
Are you a Comet Garden Expert? Answer questions, earn points and help others
