Question about Toastmaster Kitchen Appliances - Others
Where can I buy a new bread pan and kneading pan ? Mine was thrown out by mistake.
    Genius:
  • 1,739 Answers
You will need to know your model number.
Possible sources for replacement parts are here:
http://www.directpartsandproducts.com/toastmaster-bread-makers-c-51_1268_1277.html
or
http://www.abtecparts.com/toastmaster_breadmakers.htm
Posted on Mar 26, 2011
The paddle for my Breadman BK1060BC has been coming off during kneading. Today, I saw some grey residue in the dough. Is the problem with the paddle, pan or both? Thanks.
I just purchased this 2 days ago and started to use it. I noticed the bread pan would wobble and was noisy during the kneading cycle. On the second use the paddle came off during the kneading cycle. Being a service technician all my life, I started to analyze the problem. I was previously surprised how loose the bread pan fitted into the bread maker and suspected there should be something to support the pan and hold it in place. I could not see anything obvious, but after looking carefully I noticed spring clips on the bottom of the bread pan, and also mating spring clips in the bottom of the bread maker. If I pushed the bread pan down fairly hard into the bread maker the bread pan would snap firmly in place. This stopped the wobbling during the kneading cycle and the paddle coming off. I could not find anywhere in the manual where it explained the bread pan must be pushed firmly down into place until it snaps in. The manufacturer should explain this to their customers on their website.
Apr 23, 2011 | Breadman TR2500BC Bread Maker
My toastmaster bread machine 1142, the bread sticks to the pan and the kneading tool gets lodged in the bread after it is baked. What can I do to prevent this or do I need to buy a new bread pan and...
The next time you make your bread use the same recipe but use 2 table spoons less liquid. Having the paddle come off in the bread is not abnormal. If the bread sticks to the pan again let me know daryl441@msn.com Sometimes my paddles stay in the loaves sometimes they do not.
Mar 24, 2011 | Toastmaster 1142 Bread Maker
My paddle keeps coming off when the dough is mixing. What's up with that?
Your paddle is probably worn out and has too much play in it. Some play is necessary to get it off for cleaning but it shouldn't be so loose it is coming off during kneading.
Nov 14, 2010 | Breadman TR444 Bread Maker
Sqeaking when kneading oster 2 loaf bread machine - how to oil?
Take out the bread pan and go to a kneading cycle. See if it is squeaking. If yes, then it could be the belt squeaking on the pulley or the motor itself. If it does not squeak when the pan is out, then it's the bread pan paddle and sealed bearing. That sealed bearing is lubed and sealed. It can't be oiled. Hank
Jan 18, 2010 | Oster Kitchen Appliances - Others
The post holding the kneading blade came out of bread pan
The sealed bearing on the bottom of your pan is broken. There is no fix for it...sorry. If under warranty sunbeam will replace it. Try looking on eBay for a new pan. ( I have same model as you and the bearing froze after 5 years of heavy use. The pans on eBay were very expensive, so I bought a new Sunbeam iat Walmart in New Hampshire for just under $50.00 and no tax).
Dec 12, 2009 | Kitchen Appliances - Others
The driver that operates the kneading blade ( paddle) is falling out of the baking pan from the bottom. It appears a washer has disintegrated. Pieces seemed to fall apart when cleaning. any suggestions? I...
There is a sealed bearing at the bottom of the pan. This allows the paddle to rotate. The bearing has failed and is falling apart. This usually happens with age or use. Time for a new bread pan. If you are lucky you can find one on ebay. Sorry for the bad news....Hank
Dec 09, 2009 | Oster 5838 ExpressBake Bread Maker
Bread pan pops out during kneading, hard to remove after baking
I have Breadman Ultimate for over 12 years now. I make bread 2-3 times a week for the past 10 years. I found that the bread pan popping out only happens when the motor shaft and the kneading paddle are not tightly engaged. I find this problem in the following two scenarios: 1. The bread pan was not pushed down all the way as described by cassie_hobbs and tlcquiltnut. 2. Debris filled up the motor-shaft bowl underneath the bread pan to prevent a tight engagement of the motor shaft and the kneading paddle. These debris are generated during the kneading process; part of the ingredients is pushed out of the shallow horizontal pan and accumulated underneath. To avoid the problem, I have to periodically remove debris from the shaft bowl and make sure the pan pushed all the way down. To reduce the debris, I made a simple cover for the bread pan by cutting an old aluminum baking dish. I always remove the cover after the kneading cycle to prevent the rising dough from reaching the bottom of the cover. Hope this helps. Wendy
Feb 22, 2009 | Breadman TR2200C Ultimate Bread Maker
Missing part for a bread machine
sometimes they're sold used on Amazon- search there under the model name and number
Feb 07, 2008 | Toastmaster 1183N Bread Maker
Bread machine pan and kneading blade
here's the manual if you need it http://www.bread-maker.net/Bread-maker-reviews/Product%20Manuals/Betty-Crocker-BCF1690.pdf freefone for spares from manufacturer: 1-866-819-4335 hope this helps :)
Mar 06, 2007 | Betty Crocker BCF1690 Bread Maker
Kitchen Appliances - Others Logo
57 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oscar Netto
Oscar Netto
Mohamed Ismail
Mohamed Ismail
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
