Question about KitchenAid Pasta Roller & Cutter Set Kfetpra
Why does my spaghetti cutter only separate every other noodle?
2 Suggested Answers
  • 905 Answers
SOURCE: KitchenAid KP2671 - Spaghetti cutters stopped turning. Makes loud noise.
this is common for any device that has a motor,either the gears are grinding or the motors contact brushes need replacing, it will have to be looked at to determine the exact cause
Posted on Oct 13, 2008
What kind of sealant do i use for leaking gasket
I use a product called Gasket Black. Basically it's silicone. it is available in Black and Grey. when you put it on the gasket make sure there is no oil or other contaminant (like antifreeze for example) and when you use the silicone you want a small bead in a continuous line all around the gasket, DO NOT spread the silicone flat you want a line about the size of a spaghetti noodle.
Dec 19, 2014 | 2000 Kia Sportage
Broken input shaft
KitchenAid doesn't sell any internal parts for the KitchenAid pasta attachments, the only thing to do is buy a replacement, if it is just the pasta roller you can purchase the KPSA, if not the others are just sold in the KPRA pack
Mar 07, 2014 | KitchenAid Kitchen Aid KPRA Pasta Sheet...
My Pasta Queen does not lock into the number settings
You are probably missing or have a bad cog in the setting gears.
Feb 24, 2013 | Marcato Atlas Pasta Queen hand-crank pasta...
Kitchen aid pasta roller
Hi, you may have a broken shear shaft. Here is a link to replace it.
http://www.ebay.com/itm/KitchenAid-Pasta-Roller-Attachment-KPSA-Repair-DIY-Hex-Shear-Shaft-Replacement-/281539451678
It also comes with instruction on how to replace it.
Feb 12, 2013 | KitchenAid Pasta Roller / Cutter Set
Where can i get gears for kitchenaid pasta roller
Not a solution, just want to echo the problem. There are solutions for the shaft, but when I opened this up I found a stripped nylon gear attached to the shaft. Kinda sucks: I recently replaced the nylon worm gear in the mixer, now I have to do the same in the spaghetti cutter. I can't find the part or any mention of it anywhere.
Jan 17, 2013 | KitchenAid Pasta Roller / Cutter Set
When cutting noodles they are coming out two noodles together? why?
Your blades are not completely set in their tension. You may have to replace the blades.
Nov 24, 2012 | KitchenAid Pasta Roller & Cutter Set...
I got the brush stuck in the spaghetti cutter attachment. I turned off the machine but we can't get the brush out.
I had the brush get stuck in my spaghetti attachment and the attachment would not turn. My husband got out his drill with the smallest bit & he drilled a hole through the teeth of the spaghetti attachment & the bristles fell out. I can now make spaghetti once again.
Aug 08, 2011 | KitchenAid Pasta Roller & Cutter Set...
Oct 13, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid Pasta Roller & Cutter Set Kfetpra Logo
88 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
