Have double image and a red outline to the right?
  • floresmusic Aug 04, 2008
    The model is AV-48WP34. About how much does that run to get fixed?
  • 8,617 Answers
Convergence Ics need to be replaced . please respond to this same post with your model number and I will post the correct ics for your model and where to get them.
Posted on Aug 04, 2008
Double image and colour
There are two common problems with these sets.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Lots of red in pics otherwise great
If you have double image sounds like you have a convergence problem which is very common with these units.Part #STK392-110
Jan 12, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Double image in bright blue with philips model 55pw9363/17f
You may have 1 of two problems.
1) Convergence Chips are failing - Using your original remote goto the "convergence" screen.
Try to adjust the red - UP - DOWN - LEFT - RIGHT
Next try to adjust the blue - UP - DOWN - LEFT - RIGHT
If you can move both colors in all directions you do not have a convergence issue.
If you can't move one or more colors in one or more directions the convergence chips are defective and need to be replaced.
If your convergence chips test out ok the most likely problem is......
2) CRT Coolant is cloudy  - The bright outline you described is one common symptom. Other symptoms include dull images, red or orange tint, halo around images.
If you goto the site - and click on "Tips" - you will find more detailed instructions on how to check the convergence.
Dec 04, 2008 | Philips 55PW9363 55" Rear Projection...
My toshiba 42pw33p television show double image
If the convergence controls don't fix the issue then the convergence circuitry is most likely faulty. A Toshiba repair center will be able to get you an estimate for repair.
Oct 31, 2008 | Televison & Video
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Double images with red halo outlines
Sounds like your describing convergence ICs. They cost about 10.00 each and you will need to replace both of them. And possibly the resistors that power them total cost under 30 dollars if you do he soldering yourself. Hope this helps.
Feb 10, 2008 | Zenith B50M88W 50" Rear Projection...
Mitsubishi platinum plus ws-55857
Solder connects = temporary fix.......Replace IC'
order two STK392-570 good quality.....16 to 22.00 each
Dec 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
