Question about Microwave Ovens
I changed the water feed for the ice maker from copper to plastic and now the ice tastes funny. Why?
  • 4,354 Answers
Probably plastic tubing, try flushing, with a LOT of water. It should settle down after a while, but flush heavily.
Posted on Mar 26, 2011
Plumbing in water supply to fridge.
if this is for ice maker this is how its done. run the line through the floor in back of fridge to a cold water pipe. closest to where fridge sits.
  • Turn off the cold water supply to the pipes.
  • Attach a pipe clamp to the cold water pipe.
  • Screw a packing nut into the cold water pipe. Turn the packing nut until it punctures and taps into the pipe. Attach ¼-inch copper tubing to the outlet valve on the packing nut using a compression nut. Make certain the valve is closed before you secure the packing nut.
  • Attach the copper tubing to the intake connection using a compression nut. to back of fridge,
  • Turn on the cold water supply.
  • Turn on the outlet valve on the packing nut.
  • the kit should have directions with it. good-day !
    Aug 20, 2011 | Microwave Ovens
    I installed a new fridge filter and now my ice maker will not make ice.
    Check the direction of the water flow for the filter, did you put it on backwards? Did you open the pep-**** to allow water to flow to the unit again? Did the ice-maker line freeze up when you were changing the filter. These are all things that are common mistakes when changing the filter. Check this things out and get back to me with an update...
    Jun 14, 2011 | Microwave Ovens
    Have Kenmore sid-by-side refrigerator: 7909621940B - Just changed water filter. Now, no water or ice dispenses. Ice maker is making ice - filled the bin over a few days. But, when I push to dispense...
    We also have a kenmore side by side refrig and had the same problem,,,
    FIRST, CHECK THE CONNECTION BETWEEN NEW FILTER AND ATTACHMENT POINT,,
    IF THE RUBBER GASKET CAME LOSE DURING THE CHANGE, IT MAY BLOCK THE PATHWAY FOR WATER TO FLOW
    NEXT, CHECK THE WATER/ICECUBES/CRUSH LEVER SWITCH TO MAKE SURE IT IS NOT PART WAY BETWEEN ONE OF THE SETTINGS,
    NEXT,CHECK TO SEE IF YOUR UNIT HAS A RESET BUTTON,
    THE RESET BUTTON IS USUALLY IMMEDIATELY INSIDE THE OPENING WHERE THE WATER/ICE DISPENSES AND UP, YOU WOULD NEED TO PLACE YOUR FINGER RIGHT DIRECTLY UP BEHIND THE FRONT PLASTIC COVER, AND IT'S GOING TO BE A VERY SMALL BUTTON, I AM NOT SURE WHICH SIDE ON YOUR UNIT R OR L, BUT DIRECTLY UP IN THE CORNER,,
    I HOPE ONE OF THESE HELPS !! angi
    Feb 05, 2011 | Microwave Ovens
    Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
    Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
    2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
    Jan 15, 2011 | Microwave Ovens
    Inserted K cup and closed machine. Says Brewing but coffee machine only dispenses a few tablespoons of water...tried turning machine off and off, but same amount of water is dispensed each time, no matter...
    Sorry to read about your issue.
    The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
    Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
    Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
    If you taste vinegar..use more clean water, until the taste is ok.
    I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
    Jan 01, 2011 | Microwave Ovens
    Ice maker will not make ice
    hELLO THERE:
    There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
    Dec 29, 2010 | GE Microwave Ovens
    Is my Keurig coffee maker pump broken? I am only getting partial cups...
    For some reason, your post is under microwave...????
    try doing a vinegar/water cleaning..
    Run 1/2 cup vinegar to full tank of water...keep out the k-kup..just keep running until empty..then run fresh tank of water thru. until bad taste is gone...
    Dec 18, 2010 | Microwave Ovens
    Not making ice. water is getting to the water dispenser but don't know why it is not getting to the ice maker itself. how do i check it/repair it.
    Hia and wl;ecome to FixYa, I am Kelly.
    We really need a make and model number to provide you with specific unit applicable information but.... in general, here goes:
    1. Ice makers must have a freezer temp below 16 Deg F. If there is an airflow problem in the freezer caused by a fan or ice build up the ice maker will no longer make ice.
    2. The ice maker has a thermostat that controls the harvest and fill cycle. If the thermostat fails it will stop making ice.
    3. There is a water valve in the back of the unit that has TWO electric solenoids on it. One for water in door and one for ice. If a solenoid fails it will stop providing water to the applicable function. I.e water in door or ice. You can briefly remove the fiberboard back cover to gain access to the water valve. Then switch the installed terminal connection between solenoids. Left to right or front to back depending on how it is mounted. Then try the water in door. If water flows to the ice maker when water in door switch is actuated then the solenoid for making ice is good and the probem is with the icemaker. (Reconect wires in original positions.)
    Note that anytime you remove power from the unit you must wait 10 - 15 mintues before re-applying power so the coolant system can stabilze. Other wise the compressor will not start.
    Here is a web link that will help most people troubleshoot ice maker problems:
    http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
    The link above is pretty good.
    There is a 48 page job aid also for whirlpool in door ice that is also a big help:
    http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
    This should help you find out why it is not making ice.
    Thanks for choosing FixYa,
    Kelly
    Oct 26, 2010 | Microwave Ovens
    Model # trt18GREW5 ice maker will not make ice, and no water flowing thru valve w/ water supply on and water tube to ice maker disconnected
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Water doesn't flow unless the ice maker calls for water which it does immediately after dumping the previous load of ice.
    Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
    The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
    Dec 18, 2009 | Microwave Ovens
    Microwave Ovens Logo
    83 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Marvin
    Marvin
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
