Question about Flotec 2115 Swimming Pool Cover Pump 1790gph 14hp
My flotech pool pump stops running and then later on starts working
    Top Expert:
  • Flotec Master
  • 8,514 Answers
Motor overheating replace
Posted on Sep 20, 2017
5 Suggested Answers
mattofilms
  • 110 Answers
SOURCE: intex pool filter/ pump just stopped working
Try giving your pump more air circulation.
Turn off pump when not around it.(should only need to run for around 3 - 4 hours on a small (kid) pool 6 - 8 hours for standard house pool
You could put you pump on a timmer - set shut off time to just before you pump shuts down.
Check you pump (when not conected to mains power) - get some WD40 into it - (salt and metal no like each other)
Posted on Jul 07, 2009
SOURCE: I have a Flotech FPOS1790PCA Pool pump that will
I have the same model and found that it frequently shuts off when it gets too much pine needles clogging the strainer.
I have unscrew the bottom "skirt" almost once a month and clean it out.
Posted on Mar 15, 2010
thepool
  • 78 Answers
SOURCE: pool heat pump won't keep running
It is likely that you have a low refrigerant condition and require an HVAC person to service the unit. It's not unusual to need "freon" every so often. Call the repair man...
Posted on Apr 22, 2010
jharwell668
  • 640 Answers
SOURCE: my pump will stop and restart a few minutes later
With these pool pumps, it is probably either that you are getting air pockets or leaks in the suction line or your pump strainer is clogged.
Posted on Sep 29, 2010
Sand coming into pool when set on filter and when back wash and rinse? How do I stop this?
Sand can be sent to the pool for several reasons. If it is piped in reverse, if the laterals, their manifold, pipes connected to the manifold is damaged or there is a problem in the backwash valve. The water from the filter enters the filter above the sand where it soaks through the sand, through the laterals and out the return pipe to the filter. If the water is flowing from the pool into the laterals and through the sand and into the pool some sand will go with the water into the pool. In addition, the laterals will get filled with dirt from the pool. The best way to know if there is a damaged lateral, manifold or pipe is to remove most of the sand and inspect these parts. After the filter is worked on, If some sand was in the laterals, manifold or pipes when a system is started it should be sent into the pool and find can then be brushed into the main drain and be caught in the filter. I hope this helps.
Aug 14, 2011 | Hayward SAND FILTER, PRO SERIES
Why is sand shooting back into pool
Inside the sand filter there are laterals that are PVC pipes with many narrow slots along their length. If a lateral is broken then sand will not be stopped by the lateral. Another possibility is that the part these laterals screw into is broken and sand leaks through. I hope this helps.
Aug 07, 2011 | Waterway 22" Swimming Pool Sand Filter W15...
SAND SHOOTS INTO POOL
Probably a broken or loose lateral in the bottom of the filter. Do you backwash a lot? One thing you might try if the lateral isn't too damaged is let it run for a day, vacuum the sand out of the pool and see if it stops. If this works, good. But the next time you backwash, you will have to do it again
Jun 05, 2010 | Hayward S166T Pool Filter System w1 HP...
My pump will stop and restart a few minutes later during its programmed run time, during warm and cold weather, the pool water is in the 50's.
Mar 01, 2010 | Pentair Wf 6 1.5hp Whisperflo Inground...
I have a Flotech FPOS1790PCA Pool pump that will run for 15 seconds and then shut off...how do I get it to stay running?
Nov 22, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Pump Doesnt work.
to start , you have to give details like make , model year of the pump and what it is used for
post you statement again and include the details as posts are not linked
Apr 11, 2017 | Intex Easy Set 530 Gallon Swimming Pool...
My pump works for a little while then it stops for no reason. We can't get to start, it is hot. A few hours later, it will start again but only for a couple of hours.
Something is causing it to overheat; the shut off is automatic and is saving the pump from burning up. The pump may be failing or there is something overloading it causing the heat.
Try to make sure it is clean and free of any blockages not allowing air to flow around it.
Otherwise, plan on a new pump soon.
Jun 25, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex pool filter/ pump just stopped working
Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Flotec 2115 Swimming Pool Cover Pump 1790gph 14hp Logo
118 people viewed this question
Top Flotec Pool & Spa Experts
Jay Finke
Jay Finke
Bill Boyd
David Spradling
David Spradling
Are you a Flotec Pool and Spa Expert? Answer questions, earn points and help others
