Recently setting up my printer Ricoh GX3000s for the first time and I am getting *Warning* System Error S001, I saw your solution for the problem but when I lift the scanner lid theres no switch there to unlock the scanner.....please help
  • 1 more comment
  • charlott_wil Mar 26, 2011
    Ezrahite thanks for your help with the system error, I found the unlock button, but now the printer is saying the duplex cover is open and please close i'm not sure what how to resolve that issue, I have power the machine off and back on and that is still displaying
    nevermind i am up and running now thanks for all your help...I really appreciate you
    Issue resolved thank you so much for your help
  • 2,632 Answers
Welcome to Fixya. There's shipping "lock" on this printer, basically a plastic tab under the scanner mechanism, that must be moved to the "unlocked" position.
Thanks
Posted on Mar 26, 2011
  • Rofel Lantican
    Rofel Lantican Mar 26, 2011
    Here's the guide that will fox your problem. Please click on the link below.
    Duplex Cover Open Fix
    You can also use the link below on how to troubleshoot error problems on your device. It contains screenshots for quick reference.
    GX3000 Printer Function Error Message
    Hopefully this will fix your problem. Thanks for using Fixya.
  • Rofel Lantican
    Thats nice but the link will be helpful incase you experience a problem. If i was able to help please rate me so i can help others aswell. The 4 thumbs is across my name on my first solution. Thanks
Service call-sc491
Possible fixes from previous FIXYA question.
Use Comment menu to add information.
For example, what model Ricoh printer is it?
Have you replaced toner recently? If so, was it Ricoh original or not?
http://www.fixya.com/support/t26593905-printer_ricoh_sp_210su_service_call
Printer Ricoh sp 210SU service call error SC491 using compatable cartridge...
Jul 10, 2018 | Ricoh Office Equipment & Supplies
Error s099 printer gx3000s
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
Jun 17, 2016 | Ricoh GX-3000S Multifunction Color Printer
Erro s001 gx3000s
If you wish to get some details; check the site linked here. Pull up older posts.......
Jun 17, 2016 | Ricoh GX3000sf InkJet Printer
How to solve system error s001
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
Jan 23, 2013 | Ricoh Gx3050sfn All-in-one Inkjet Printer
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
After replacing the ink waste tank, I am still getting an error stating replace waste ink tank full on an Ricoh GX3000 all in one.
This may have to do with the method of replacement. Leave the printer on, remove the waste tank, clean the area (sensors may detect residual ink) replace the empty waste tank. If this doesn't work, there may be a chipset on the waste tank to indicate end of life. This is a way for the manufacturer to continue making a truckload of money from the end user. Generally the only way around this is to modify your printer to by-pass this part of the circuit (an electronic solution to replace the chipset). This method will most likely void your warrantee.
Aug 25, 2010 | Ricoh Aficio GX3000S multifunction Ink...
I have a brand new Ricoh GX 3050sfn. When I cnonect it and turn power on, I get system error s001. What can I do?
The travel lock is on open the top and on the front left underside there is a switch push it back and it should work fine
Dec 20, 2009 | Ricoh Aficio GX3000 All-In-One Printer
First time I turned the power on the machine said "Warning system error S0001"
The cause is the lock lever of scanner unit is locked. Lift the scanner lid and unlock the scanner unit with the switch located under the lid on the left side.
Jun 03, 2009 | Ricoh GX3000S InkJet Printer
Open heat error
From looking at the manual it looks as if you have a faulty thermistor. When warming up, it has to heat up to at least 60 degrees. If it stays lower then 60 degrees celsius for over 35 seconds and doesn't reach 60 within that time frame then that would cause the open heat error that is happening on your machine.
Feb 09, 2009 | Ricoh AficioSP 5100N Laser Printer
Error message
Not sure if your printer is the same, but one ricoh I saw had an energy saving setting, that's meant to play with the warm up time of the heating roller. If you still have the manual and can find the access to such settings, you could try it with each one of the settings, to see if it fixes the problem. It's possible that with energy saving turned off your problem will be solved, which isn't a bad idea for a frequently used school machine. If it does solve it, you could ask the users to make sure the machine is turned off when it's not being used for a long period of time. Good luck
May 18, 2006 | Ricoh Aficio CL2000N Laser Printer
196 people viewed this question
k24674
jasbo
jasbo
