Question about Whirlpool LER5636P Electric Dryer
Admiral dryer agd4475tqo wont heat up - Whirlpool LER5636P Electric Dryer
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Apr 02, 2011
Admiral dryer wont heat, will run. Continuity on all wiring....what next?!
gas dryer check the thermocouple ---electric check the heat element
Jul 31, 2016 | Admiral Dryers
Admiral dryer wont dry clothes
one of several things can cause this . contacts in the timer , heating element ,door switch to name a few .plugged lint filter also can cause poor drying as it slows the air flow .when all else fails call a service tech
Mar 13, 2015 | Admiral Dryers
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Admiral Dryer, runs bu t does not heat
The thermostat, timer or the heating element itself are the places to check. Look at the circuit breaker for the dryer in the power panel. It will be two breakers connected together. If one trips but not both, the heating element will not heat but the dryer will run.
Nov 17, 2014 | Admiral Dryers
Admiral dryer timer not turning and no heat
It could be the high temp fuse on the element and the timer not turning depends doyou have it on the auto dry because it will not advance if it is not heating because the sensors are not detecting a decrease in the humidity levels because the element not working.
Mar 14, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
Admiral dyer model ade7000ayw wont make heat
You will need to replace the heating element and the thermostat. They come in a kit and is a simple job to replace them. Here is a link to the kit.
Oct 14, 2012 | Admiral Dryers
Admiral dryer model aed4475tq1 wont start
Take a look at this troubleshooting tip for the no heat problem and no start, for your dryer.
Oct 21, 2011 | Whirlpool LER5636P Electric Dryer
The dryer runs fine but has no heat. The exhaust and lint screen are clear of debris. It is a Maytag MD3000
The Heating Element may be gone, or you might be real lucky and have a loose or dirty connection.
You might want to throw the Breaker Switch or unplug the unit before you do anything (220!!!).
Jun 02, 2011 | Dryers
Heating element
Might I suggest this site if you are a do it your self.
http://www.appliancerepair.net/dryer.htm
You have to raise the top take off the front and the tub should come out. Wala the heating element. Hope this helped, if not let us know.
Mar 16, 2009 | Dryers
Whirlpool LER5636P Electric Dryer Logo
408 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
