Question about Kenmore Freezers
Basement flooded with 9 inches of water. I have allowed the freezer to dry out. When I plug it in the inside light and the control panel both come on. But the compressor does not run. Any ideas ???
  • 2 more comments
  • Sean Miller Mar 26, 2011
    Hi is the upright? Do you have a model?
    Sean
  • sgunsett Mar 26, 2011
    It is an upright Kenmore model 253.26742101
    I have one more question is the fan running in the freezer ,and when you say controal panel does it have a digital display?
    Sean
    The fan does NOT come on. The control panel is in the freezer compartment and it is digital.
22yooper
  • 828 Answers
SOURCE: Frigidaire freezer not working
The thermostat may have shorted out so that it is no longer making contact to put power to the compressor. After drying out the components try bypassing the thermostat and see if it will start or make any sound whatsoever. If it does start and run with the thermostat bypassed replace the thermostat. 4-6 inches of water can also get to the relay on the compressor. Replacing the relay and over load assembly also be a good idea.
Posted on Sep 15, 2008
ryanmalin
  • 40 Answers
SOURCE: why would my Chest freezer be flooding my basement
freezers still make condensation like air conditioners. they have a drain line heater to keep the condensate liquid until it exits the freezer. then it goes into a drain pain that usually has the high (hot) side line running through it to evaporate the water and at the same time increase efficiency. you probably have a rusted out drain pan which you can replace. you can make one from sheet metal and just seal the corners with RTV silicone, be careful sheet metal WILL cut you badly, so wear gloves whenever handling that stuff.
Posted on Oct 10, 2009
Testimonial: "Thank you for the info. "
jyackle5
  • 8197 Answers
SOURCE: basement flooded and chest freezer was down there.
Yes it will work again. But I would not trust it. If you do want to use it you will want to let it dry out fre at least one week.
Posted on May 25, 2010
heatman101
  • 43501 Answers
SOURCE: The compressor sounds like it is running but it
In this case if it is not something simple... it will be cheaper to replace...checkout these tips for the simple stuff.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 17, 2010
  • 1531 Answers
SOURCE: Frigidaire Freezer RIP 10-11-10.
yes you need to replace the circuit board
Posted on Oct 13, 2010
Upright freezer got wet @ bottom when basement flooded, is it worth fixing?
If you replace the starter on the compressor unit and start capacitor and timing unit, will work as new. good luck, take ur unit upstairs next time. Russ
Sep 02, 2011 | Whirlpool 19.6 cu. ft. Upright Freezer...
I had a flood in the basement where I keep my Frigidaire freezer, model FFU17FC5W3, which left 4 inches of water on the ground. The following day I drained the basement and dried it up and the freezer was...
Welcome to FixYa.
Likely just the start device, the compressor is a sealed unit so the water would not have affected it.
Here's what I'd suggest you try...
If you feel like you can trouble shoot further I`ve provided the following info to assist you or you may decide to call a professional appliance technician as I would suggest.
I don`t know the age of your fridge, but I should mention...
** Most of the manufacturers of fridges have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to.**
If you have a multi- meter you can check the compressor to see if the windings are ok.
**First, Unplug the fridge**
Remove the panel at the back down at the bottom. This should gain you access to the compressor.
On the side of the compressor will be the start relay/overload assembly such as this image...it may be enclosed in a black plastic cover as well.
Pull off the relay & overload and you'll see 3 pins in the form of a triangle...
With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin.
You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms.
On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good !
If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit.
i.e.
The above package contains info and hardware on how to connect it.
NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relied on for long term reliability or safety, but rather thefactory replacemnet, double check with your model number.
Hope that help`s move you forward if nothing else. If so please take a second and rate the reply and a testimony to your inquiry you received here at FixYa.
Thank you and good luck.
Regards,
Macmarkus :)
Mar 18, 2011 | Frigidaire 17 cu. ft. / 481 liter Upright...
Frost build up especially on top shelf all other shelves except one gets a 3 inch layer of ice in approx 4 months. The freezer is kept in a mod temp basement room and the freezer door is opened less than...
Things you can do to cut down on frost.
1.make sure all seals fit flush to frame.
2.use a thermometer and set freezer to -18c(beef will keep upto 12months).
3.wrap all food as airtight as poss.
3.do not overfill,leave space for air flow through drawers/shelves.
4.defrost every 2/3 months in humid conditions using clorine bleach to clean interior,and dry thoroughly.(leave door open to dissipate clorine gas.)
Aug 18, 2010 | Woods Upright Freezer V1613RW3
What could be causing my 7 year old upright Frigidaire Model FFU21K2CW0 Freezer to NOT freeze? The inside (of the compartment) coils feel cold, the seal is good, but the ice cream is VERY soft. The...
Your freezer is probably running constantly as well. Lift the bottom vent panel (the one with all the holes in it) and look at the bottom of the back panel. There should be a half inch gap for the cold air return. If you see a solid wall of ice in that gap your coils have frozen over. You need to clean out the freezer and defrost it. Look in the back near the compressor. If your model does not have a drain plug in the bottom then you need to leave the door open and mop up the water as it melts off the coils from the inside. If you can, wheel it outside on a dolly and let it defrost where it can drain on its own. After you are sure it is totally defrosted, plug it back in at a control setting of 5 for at least 4 hours, preferrably overnight, and check the temp. Setting the freezer at 7 will encourage ice buildup. Your problem may be a bad defrost timer, which your local appliance parts store may have.
Aug 03, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Basement flooded and chest freezer was down there. Any chance the freezer will work again or is it junk?
May 25, 2010 | Frigidaire 13 cu. ft. / 368 liter Chest...
Upright frigidaire commercial freezer has no power, we had a flood in the basement. I unplugged it now the the water is gone, it will not power back on. Is there a reset button or did the moror fry from...
Water damage is hard to remove because it could have goten to the electrical parts: motor, compressor, timer, etc.. while it was still running. you need a volt meter to test these parts out no reset sorry
if it was running with water then toss it out...
sorry
call a service guy and he will tell you the same for $80!!! save your money
you can try to raise your freezwer off the ground when you get your new one...
hope this was helpful
Mar 28, 2010 | Freezers
Why would my Chest freezer be flooding my basement while it is still frozen inside
Oct 10, 2009 | Freezers
Sep 13, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezers Logo
230 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
