Question about Kenmore Dryers
My dryer runs and heats but seems like no air is being blown. It should have some sort of a blower correct? Taking 2 cycles to get dry and vent is not clogged, but not sure about lint trap slot.
  • jerry earick Mar 26, 2011
    Does the dryer make a rattling sound when it starts?
    Scholar:
  • 79 Answers
First, of course, make sure ALL the airways are clear, including the area around the lint filter, and the outside vent - lint likes to stick to the outside vent flap, so make sure you clean that off too, and that it opens and closes freely.
Here's how to get the dryer apart
http://fixitnow.com/wp/2004/03/22/appliance-tip-of-the-day-encore-dryer-disassembly/
There is a blower wheel, but it's powered by the same motor and belt which turns the drum. So if your drum is turning, the blower wheel should be turning, too. If not, you may have to replace the blower wheel. Here a link showing how to do so:
http://fixitnow.com/wp/2010/06/30/replacing-the-blower-wheel-in-a-whirlpool-built-dryer-with-the-lint-filter-in-the-door/
Posted on Mar 26, 2011
Why do clothes take a long time to dry even if dryer is heating?
One basic reason is your washer could NOT be spinning most of the water out, therefore your clothes are wetter than they should be, thus taking longer to dry:-)
Jan 22, 2015 | Whirlpool Dryers
Tip
Taking to long to dry
The most common problem for a dryer to take more than one cycle to dry is restricted air flow.
1.when the dryer is running go outside and find where the venting is located, there should be a good amount of air flow.
2. if the air flow is not good look at the ducting coming from the back of the dryer and make sure it is not kinked or pushed back to far.
there is usually lint build up some where along the ducting or at the end of the duct where it vents to the outside.
3. if you have access to a leaf blower,this can be used to help clear any lint build up inside the duct from the dryer to the outside venting.
move your dryer out and take the leaf blower tube and stick it in the hole and turn it on.
the vented louvers need to be removed from the ouside of the house to allow the lint and things in the duct work to be blown out.
on Jan 25, 2010 | Dryers
What is wrong with my dryer?
the squeaking could be due to bad rollers or pully system? if the drum is not tight and sitting correctly on the pulleys it will allow heat to escape? check these as well
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Oct 19, 2014 | Dryers
Needs two cycles to dry clothes!
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 19, 2012 | Kenmore Dryers
Dryer functions seem normal, barrel rolls, air is circulating and it feels hot, however clothes are not dry after several cycles/hours.
Mar 06, 2011 | Whirlpool LEQ9858P Electric Dryer
It takes the dryer 2 hours to dry the clothes. I always make sure lint filter is cleaned after each cycle.
Hello there and thanks for choosing fixya
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Feb 03, 2011 | Dryers
Dryer taking too long to dry clothes
Jan 09, 2011 | Maytag MED5700TQ Electric Dryer
Maytag gas dryer doesn't dry properly
SOUNDS LIKE A RESTRICTION IN THE VENT. CHECK AIR FLOW WHERE VENT EXITS HOUSE. IF IT IS NOT STRONG, INSPECT VENT LINE BEHIND DRYER. IS IT CRUSHED OR CLOGGED WITH LINT? THIS WILL CAUSE DRYER TO SHORT CYCLE. IF VENT IS NOT CLOGGED, CHECK AIR FLOW AT BACK OF DRYER WITH VENT DISCONNECTED. IS AIR FLOW STRONG? OF NOT, PROBLEM IS WITH BLOWER.
Jan 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
DRYER DOES NOT DRY BUT CONTINUOUSLY RUN
Run the dryer for a minute, then open the door and check for heat. If there is heat, the element is ok. If so, you've got a venting issue. If there is a restriction in the vent you won't be able to get as much air out, therefore you won't be able to get as much of the moisture trapped in the air out. The auto dry settings on some dryers require the operating thermostat to open to advance the timer. If there is a venting issue it may cause the dryer to cycle with the hi-limit thermostat instead. Of course, it should not affect the timed dry cycle. so if it won't advance there either you may have another issue. Try taking the vent off the back of the dryer and allow it to vent into the room. This may take care of both of your issues if the restriction is in the home venting, then you would need to sweep the home vent. It's also possible that the restriction is in the dryer blower housing. Without the vent hooked up, turn the dryer on and feel where the vent leaves the dryer. You should have a fairly strong movement of air, if not you'll need to disassemble the dryer and remove the restriction.
Jul 21, 2008 | Kenmore Dryers
This could be two problems. First problem, you must have good ventilation. Blow out the dryer vent with a leaf blower or some other type of fast moving air. Also be sure that the vent on the outside isnt blocked by little woodland creatures trying to find a nice warm home. Also be sure that the vent isnt kinked or blocked between the dryer and the wall. If that doesnt work, you may have only 1 of the 2 elements actually heating behing the drum. This would entitle removing the front and drum to check. Let me know if you need further help.
Dec 08, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Dryers Logo
66 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
