Question about Coleman Heating & Cooling
My York Stellar heat pump runs for some time normally. Then the thermostat light starts blinking 4 times (error code 4). However, the discharge line gets normally hot. It will work ok again for a time after I reset the error code. thanks
  • 96 Answers
Your outside unit has a processor with an LED that also blink the error code. Check the ledger on the access panel, instruction sheet or on processor for explanation of the code
Posted on Mar 26, 2011
Whirlpool dishwasher model# gu2200xtss3 normal light flasing all the time turning power off does not help in a few minutes back on flashing
The light blinking is an error code--usually it will blink a certain number of times, pause, then blink another sequence(ex. 4 times, then 3 times)in a binary error code. There is a chart in the service manual to decipher the code(s) and locate the issue. It could be anything from a heater circuit failure to the drain pump being jammed. Try to see how many times the light blinks, and which ones blink--there could be, on the first part of the sequence, normal light, then, 2 or 3 lights blink-- I need to know which ones are lit. Thanks! You can try to look up the light combinations on the net with a search for your model number and error codes.
Oct 12, 2015 | Whirlpool Dishwashers
Buttons on the dishwasher's control panel is not working. When starting a "normal" load, it switches to "clean" and does not start the wash.
Hello. Most likely, the humming sound you hear is a jammed drain pump which is activated immediately to pump out any stale or standing water below the level which you can see. Then, fresh, hot water enters the tub to start washing the dishes. I need the model number and exactly what lights are blinking--those blinking lights are error codes(combinations of 2 or more lights, one light blinking a certain number of times, then blinking again, a different number of times--ex 3 times, then 7 times) the lights blink a binary error code--thats why I need the model number to look up the code on the chart
Sep 10, 2015 | KitchenAid Dishwashers
Clean light blinks
clean light blinks is a form of error codes. The most common is a heater circuit error, 7 times then a pause is the heater. to clear the code press the heated dry then normal in a key dance 4 times. this starts a diagnostic cycle, takes several min to complete. let it run. it will work until it sees the fault again. this code is caused when the main control does not read a water temp increase 3 times in a row. If this continues call for service.
Jan 08, 2012 | Maytag Dishwashers
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Blinking Green Light
Here's what I could find on the your error code:
A blinking clean light that flashes 7 times and cannot be reset, occurs when the electronic control does not detect a water temperature increase during the main wash. This could be an indication of a failed heating element, in line thermostat, electronic control board and/or wiring. This problem can also occur if the main wash pump becomes clogged and it not spraying sufficiently. I hope this helps you.
PS A faulty door latch can also cause this error code.
Jun 23, 2008 | Dishwashers
Clean light keeps flashing and won't let me start
A clean indicator that flashes/blinks 7 times and then repeats, indicates a problem in the dishwasher which should be investigated and not just the control 'reset'! That is why the control will not let the dishwasher start once such a condition is detected.
If the dishwasher's eletronic control doesn't detect a water temperature increase during the main wash cycle, that symptom can occur. No water temperature increase could be caused by a problem in the heater element, its in-line thermostat, the related wiring or a problem in the electronic control.
It is also possible just the washer not spraying properly (possibly from blockage in the filter or problem in the pump), the dishwasher not filling sufficiently or draining prematurely or even a problem in the door latching mechanism's switch(es) could cause it.
*Some actual investigation should be undertaken to isolate and correct the cause of the symptom.*
Once corrected, the error display may have to be cleared from the control manually. That can usually be done by putting the unit into diagnostic mode by pressing the key sequence 'Heated Dry, Normal, Heated Dry, Normal' and then pressing cancel.
Jun 20, 2008 | Whirlpool Dishwashers
Heating & Cooling Logo
293 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
