Question about Refrigerators
Hello, LSC27990TT LG Refrigerator with TV. How can I access the interior of the door between where the cable bundle enters the hinge area at the top of the door and exits behind the TV display? I am able to remove the tv display, but the problem lies within the interior of the door. The torsion and twisting of the cable bundle distorts the video signal, so how do I get to that interior wiring harness inside the door? Do I need to remove the refrigerator door handle?
  • 833 Answers
SOURCE: Loose refrigerator door handle
weavie, this is one of those ugly little problems. Get hold of a small screwdriver, a pointy knife blade or similar and stick it into the gap, however small, between the cap and the handle. You may be able to find a small indent or similar near the bottom side of the cap. Gently pry up. It will yield. Be patient.
Posted on Dec 21, 2007
SOURCE: Refrigerator won't fit thru door.
I ran into the same problem when I moved into my old house. the door way was to small, so I had to take both doors off the refrigerator to get it through the doorway. But I found out when I moved out of the house, that I was able to open both doors and wiggle it through the doorway. It was a hassle but it was alot easier that removing the doors. Good luck.
Posted on Apr 20, 2009
MNTECH
  • 1543 Answers
SOURCE: inside of door when you open lg refrigerator is very hot
I suspect you are talking about the area between the doors. Refrigerators use a loop off the compressor to warm this area to prevent condensation from forming there. Older refrigerators sometimes used an electric heater there, but of course that increases energy consumption. You will notice that the area is much warmer when the compressor is running. All this is normal, and saving you energy.
Posted on May 26, 2009
SOURCE: Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Posted on Apr 15, 2010
SOURCE: Want to reverse door swing on Kenmore refrigerator model # 795
Actually, I have a Kenmore 795 model with the top door and bottom drawer freezer. I just tried this, based on "guru's" advice. Unfortuately, though the TOP hinge on this model is reversible, the bottom hinge is NOT. I got it all apart before I discovered this problem. Also you might want to note that the 7/16th wrench is too big for my bolts and the 3/8ths is too small. I had to use an adjustable wrench...maybe they are metric.
An allen wrench will get the handles off for you. You will find little ports for it if you look carefully.
Posted on Jun 10, 2010
How do i take the entire drivers side door off of my 2011 HHR? Its a DIY project n cant afford what the insurance isnt covering. My car was T-boned and wont even open. Basically smashed shut.
You need to have the door forced open before you can access the hinges and remove it.
Remove the interior door trim and the door can be unbolted at the door hinge area. Examine the door on the undamaged passenger side before you do anything.
Nov 04, 2015 | Cars & Trucks
How to replace door hinge
Hello there.
Well no specifics but all about the hinges are as I explain below.
All Samsung Support info about your fridge is here.
http://www.samsung.com/us/support/owners/product/RF268ABBP/XAA
So if you want Service or a dealer near to you, this is the place.
Page 9 of the user guide WITH installation manual shows how to get the hinge off.download from here
http://www.samsung.com/us/support/owners/product/RF268ABBP/XAA#
Sep 23, 2014 | Samsung RF268ABBP 25.5 Cu. Ft. French Door...
Freezer door came off at the hinge
You need to replace the hinge.
call the appropriate supplier in your area , anything else won't work.
Jan 11, 2014 | LG LRBC22544 Bottom Freezer Refrigerator
I have a gs6nbexrs01 refrigerator. The origanal problem was that the ice dispensor door would not open when selected. I removed the dispensor unit inorder to check to see if there was an obstruction to the...
I suspect you have some broken wires in the wire bundle that feeds the dispenser system in the door. Look behind the kickplate ate the bottom hinge for the freezer door. There is a black mesh covering the wires to the dispenser components. Unplug the refrigerator and see if the wires are broken inside that mesh.
Kelly
Mar 24, 2011 | Whirlpool GS6NBEXR Side by Side...
I have the lg lsc27990tt fridge with the tv in it i have hooked up the cable from my direct tv but cant get a picture i have it on catv ran it threw the channel set up but the catv goes from channel 15 to...
I have had this problem twice. I found that the tv only works if the refrigerator door is open. The first time I had the door replaced, and it worked for a while. Now it is broken again. They say it is the wiring harness in the refrigerator.
Jan 05, 2010 | LG Refrigerators
LG Side by Side Fridge LSC27990TT
It sounds like your refrigerator went into demo mode. Try this.  Press and hold the temperature and lock button together for 5 seconds to get it out of demo mode.
Sep 21, 2008 | LG LSC26905TT Side by Side Refrigerator
LG LRFD25850ST gives ER CO code on door
There is a communications error between the control board and the display board.  Check the connector located on the top hinge cover.  Remove the hinge cover and check to make sure the connector is tightly secured.
Apr 12, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
