Question about Whirlpool MH7140XF Microwave Oven
How can i unlock Whirlpool MH6150XHQ-1 i don't know?
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave timer counts down but doesn't turn on when started
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Posted on Aug 30, 2009
How do I unlock my microwave
all brands Microwave Display Repair circuit board repair ...
031d26d.namesecurehost.com/mwd/?3e3ea140
Jul 1, 2015 - All brands Microwave Oven Display Repair brand nationwide Sharp Dacor GE G.E. General Electric Samsung Kenmore Frigidaire Whirlpool free help tips. ...Press the "Custom Help" pad and follow the on-screen instructions to unlock the oven....... MH6150XLT-1 MH6150XMB MH6150XMQ MH6150XMS ...
Aug 04, 2015 | Whirlpool MH6150XMS Microwave Oven
My Whirlpool MH6150XHQ OTR microwave is dead. Checked circuit breaker and outlet with no problems there. Can't get any power- light won't turn on, nothing on display, etc. I'm hoping there may...
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html?utm_source=emails?utm_medium=email?utm_campaign=2011-10%2BHow%2BA%2BMicrowave%2BWorks%2BVersion2&utm_medium=email&utm_source=emails
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Oct 19, 2011 | Whirlpool MH1150XMQ Microwave Oven
I have an older Whirlpool over the range microwave. 2001 model#MH6150XHQ-1 I went to start it and poof, it went dead. Was it a fuse? If so where are they located and how do I get one for it?
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your model number).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 02, 2010 | Whirlpool Microwave Ovens
We have an mh6150xhq-1 microwave. It rotates, the timer works, but we don't get any heating. can you help?
In all likelihood the mangnetron is failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one
Jan 27, 2010 | Microwave Ovens
I locked my whirlpool microwave and i dont know how to unlock it
I have a Whirlpool toom which states in manual: -- To lock/Unlock....Touch and hold START?ENTER for 5 second until 2 tones sound and "L" appears on dsplay. Repeat the same if you lock or unlock. Hope this helps.
Mar 21, 2009 | Whirlpool MH7140XF Microwave Oven
My MH6150XHQ quite cooking
Assuming your turntable comes on when you try to microwave, with the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
Jan 17, 2009 | Whirlpool MH1150XMQ Microwave Oven
I now own a Whrilpool over the stove microwave. Everything works expect it does not heat the food. The model # is MH6150xhq, serial #FGMO101446. I would like to replace it with a model that has the same...
You can contact Whirlpool customer service here and they should be able to suggest a model which will be a "drop-in" replacement.
Are you not interested in getting yours fixed?
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Your manual will tell you about the warranty.
You can download your owner's manual, installation instructions, etc. here.
Sep 27, 2008 | Whirlpool Microwave Ovens
MH6150XHQ-1 Blows Circuit Breaker Randomly
The problem is from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still having problems, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Feb 12, 2008 | Whirlpool MH1150XMQ Microwave Oven
Setting clock on Amana Microwave Mod#FBG623T
It may possibly be locked, in which case holding the enter/start pad for over 3 seconds may unlock it.
Otherwise, you may want to call Maytag / Amana at:
1-800-688-9900 U.S.A
1-800-688-2002 Canada
Nov 04, 2007 | Bosch HMB402 Microwave Oven
Whirlpool MH7140XF Microwave Oven Logo
130 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
