Question about Garden
Removing top to fill hozelock killaspray container
Hozelock pressure sprayer , when I pump the sprayer the pressure release valve pops up loosing all my pressure
That's what it is designed to do when there is too much pressure, usually sprayers don't get used that much to ware out that part. You might be having trouble getting spray out the wand, in that situation it is probably clogged. You have to remove tip and see if you can clean out a little particle blocking it. I know it is easy to occur and it happens if some dirt falls into the tank while filling. Hope that helps.
Jun 09, 2016 | Hozelock Garden
How do I remove this hozelock fitting from a hose that has perished? I want to fit it on to a new hose.
Hold the top (yellow/red) part with one hand, and with the other hand unscrew the grey part to release the tension on the hose, and then pull out the hose along with the grey part. Remove grey part from the old hose, slide it over the new hose, insert new hose into yellow/red part and screw grey part.
Sep 23, 2014 | Hozelock 2065 0000 Water Stop For 3/4 Inch...
Hozelok Titan 2000 pump not pumping. Electricity is getting through, pump making a funny noise but not pumping.
You have to prime the pump first. Turn off the pump, remove the priming cap, fill with water, close, then run it. Repeat as needed to get water pumping.
Sep 11, 2013 | Hozelock Garden
I have a Hozelock garden spray oscillator that no longer oscillates. I have tried to dismantle it but am unable to easily open the internal mechanism to see what's preventing the oscillations. Do you...
Hi Simon from Hozelock, if its within warrenty, please call us for a replacement, or email us at info@hozelock.com but before you do, try cleaning the inlet filter (behind the inlet - which needs removing).
Jun 30, 2011 | Vacuums
My hozelock aquastorm 17 has stopped oscillating. Is there a solution to this problem please? Rex Smith
Hi - remove and check that the inlet filter is not clogged (remove the threaded inlet first) . If this does not work, and it is less than 2 yrs old please contact us at info@hozelock.com for a replacement
May 17, 2011 | Garden
The motor in my hozelock ac2 keeps opening and closing and the display is blank. I've put in new batteries but the problem persists. Any advice on how to fix this?
Same problem for my Hozelock ac2 after two years working couple times everyday. No warranty, no Service Center nearby. Two options: discard it or repair it myself. Using a small screwdriver I removed the front cover and then the sealed transparent lid covering the keyboard. Humidity was damaged all contacts so I cleaned using compressed air, put new batteries and set up all again. My Hozelock ac2 is working again. I think the product life cycle is two years and as usual also has "planned obsolescence". -Arthur RS
Apr 20, 2011 | Garden
Hi, I have a Hozelock Cyprio 1313 filter I inherited with my pond and new house. I Cant seem to get it working without water pouring out the two holes on the top and elsewhere. I'm not sure if I am putting...
Hi - I'm Simon from Hozelock. There should be a big o ring that goes between the lid and the tank to make a seal - is that missing ? Also there should be clips that hold the lid to the tank. Both pieces are available as spares, at www.hozelockservice.com - any probs contact info@hozelock.com or @hozelock (twitter) or Hozelock on Facebook. Best wishes.
Feb 25, 2011 | Sport & Outdoor - Others
Where do you put water in a 1996 mercury mystique. I can't tell where the radiator is. I only see the coolant container
If you fill up the coolant container it will get into the radiator if it is low. If your radiator is completely empty remove the highest hose on the engine and fill through the top of the motor. Otherwise the coolant container is the only place to add coolant. Hope that helps!
Jul 30, 2010 | 1996 Mercury Mystique
My sister gave this to me but she's lost the manual. Seems to work with whatever is already in there, but I want to empty that and change the contents. Can't figure out how to get lid off. It isn't in any...
Hello. here is the manual for your sprayer. You will see that the lid does unscrew. Chances are it has gotten a wee bit corroded and may require a little work to get it off. I recommend that you use a penetrating lubricant called WD-40. Spray it on the thread area that is accessible, wait over night for it to do it's work and it will come off.
http://www.hozelock.com/uploads/pdf/spares%20manuals/2008%20SPRAYING%20SPARES%20updated%20.pdf
Also, please rate my answer as helpful. thank you.
Feb 20, 2010 | Air Tools & Compressors
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
