Question about Mr. Heater Big Buddy Heater
Panel won't hold a flame - Mr. Heater Big Buddy Heater
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
This could have to do with the main gas feeds to the ceramic panels . they might be obstructed with a spider web or dirt,foriegn material etc.
easiest fix is to take a air compresser with a blow gun tip and blow out ant foriegn material or spider webs from the gas feed pipes to
the ceramic burners.
the gas feed pipes have large air induction holes that a small blow gun can fit its nozzle into to blow out the gas feed pipes without
having to disassemble them.
that is a big time & work saver.
I took my gas feed lines to the ceramic burners all apart, only to get out a spider web that i could have blown out with compressed air and saved myself 2 hours work.
anything inside the gas feed pipes to the ceramic burners will result in dark spots or the panels not staying lite, irratic burning
or no burning at all.
the gas needs to be able to get through unimpeded at proper flow and proper pressure for proper burning.
a spider web will mess up proper gas flow. some gas, but not enough gas will get through and ceramic wont burn well and might not hold a flame.
clean out the foriegn material from the ceramic gas feed lines.
Rare posibility,if the gas behind the ceramic element escapes around the edges of the ceramic, through a bad seal of the gasket,
this also will stop the ceramic from burning well.
mr heater is not made for easy diaassembly so try not to do more work than you have to.
use compressed air rather than taking mr heater all apart to clean out a gas feed pipe.
Posted on Oct 07, 2013
My delonghi blue flame heater has a continuous yellow flame is this normal and should it have ceramic panels
Yello is bad. The tips of the flame must be blue for proper combustion . There is an air mixture adjustment that must be made to decrease the amount of carbon monoxide. On the burner, there is a metal part that has slots on it and a screw holding it in place. Loosen the screw and , with the heater flame on, rotate that metal part until blue flame tips are seen.
Oct 30, 2016 | DeLonghi Heating & Cooling
I've got good flame replaced Powerpile pilot won&#t stay lit
The flame sensor is not producing enough volts to hold the gas valve open for the pilot light. Make sure the SIDE of the pilot flame is touching the sensor. If it in engulfed by the flame it won't work right.
Jan 01, 2016 | Cozy Heating & Cooling
Does a york diamond 80 furnace have a pilot light?
There is a diagnostic code flashed from a window in front panel of the furnace. What is it? From your description, I would bet on the ignitor as faulty. The vidoe shows this repair. Don't remove elements and sand them as this fixer did. it is destructive in many cases. York Diamond 80 furnace troubleshooting won start won light flame sensor...
Mar 08, 2018 | Heating & Cooling
How do I fix the flame sensor in a baxter oven?
Take off the right side panel and open the control panel door. Take a long screw driver and stick it in the hole where the flame sensor wire goes and remove the screw holding the flame sensor in place. Clean the metal rod on the flame sensor with a piece of fine grit sandpaper or emory cloth. Put flame sensor back in, make sure no insulation is touching the exposed metal part of the wire connector.
Feb 24, 2012 | Baxter OV300E Stainless Steel Electric...
House heater
gas fire in house and pilot will not stay alight then its the bi-metal thing in the flame needs renewing ,its brass and ivor metal and it expands to hold the valve open ,now can i please answer the car questions ?
Feb 17, 2012 | Cars & Trucks
My water heater won't light. The pilot light works. But, when I try to swtch the pilot to regualr, the flame goes out.
You probably have a defective thermocouple. The thermocouple sits in the flame of the pilot, and the heat generates a small electrical current conducted back to the gas valve, keeping the pilot gas line open after you switch it to the "on" position. That's why you have to manually hold the gas valve depressed (on) during lighting in the "pilot" position, allowing the thermocouple time to heat up enough to generate its current. A defective thermocouple will not generate the holding current.
Jan 06, 2012 | Heating & Cooling
Williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
One year old heater
Try to hold the button down for 30 seconds at least before turning the knob to ON.
If you are doing this and it still goes out after you let up on the knob, then it may needs a new flame sensor.
Jan 14, 2009 | Reddy Heating & Cooling
Pilot lights but when ignition pops back up the flame goes out
will either be the unitrol control box or the thermocouple, when you push down you are holding two magnets together and waiting for a small charge to be created from the probe in the flame , if this is not working you have no charge and the magnets won;t stick to allow the valve to open, change the thermo and see if that works first, its way cheaper than a new controler
Nov 25, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
145 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
