Question about Hansgrohe Interaktiv 2-Jet Handshower, Polished Brass
There is very little water coming out of the head. how do i take the head off
  • 349 Answers
Check out the connection line to the hand held shower. Take it appart and check out the screen and make sure it is clean. Also there is a dime shaped restrictor that reduces water consumption down to 1.6 gals. You can remove that plate and the water flow will increase. The head on the shower itself you can soak it in vinegar to clean head up.
Hope this will be of some help yo you thanks.
Posted on Mar 28, 2011
The sprinkler system is shut off but there is still little water coming out of the sprinkler head. What is the cause of this problem?
Water will continue to run back down the hills to the lowest Heads and Some water will come out.It will stop once the water in the lines has Drained out.
Oct 02, 2014 | Garden
How do I stop water from coming out of sprinkler heads after the pump cuts off
There will be water come out of the heads for a few min after they shut off to bleed the pressure off there is no way to stop it you might turn your system timer down a little
Sep 14, 2014 | Garden
Water pump is boiling on a 1999 CADILLAC DEVILLE but car drives okay vibrates a little
water pumps do not boil but engine coolant systems do from lack of water . Water pumps leak and get bad bearings but the heat comes from blocked radiators-blown head gaskets--cracked heads --fans not working and the vibration is from pistons and rings trying to bind up in the cylinders from over heat situation
Dec 29, 2013 | Cars & Trucks
Little water comes out my shower head when I take a shower, should I call a plumber, or is this something that I can fix myself?
remove the shower head. and if the water flows normal, its a clogged up shower head. if takeing a shower and the diverter valve goes bad. water will come out of the spout. check out shower head to see if its clogged. sometimes you can soak the head in a good cleaner and it helps it. but if its the showerhead thats plugged. you can always put a new one on also. good-day !
Jan 10, 2012 | Home
Epson R290 with Continuous Ink System. Even after 4 or 5 head cleans, I'm still getting banding. I never had this originally, and use this printer for high quality photo prints. Can the print head be...
Hi
Sure can be printhead can be cleaned but remember one thing you are dealing with a delicate thing and need to take care while doing this.
1. remove the head from the printer
2. Take little lukewarm water in a container (remember not to submerge the complete head in water)
3. Take a Syringe with little water in it and insert in the tip where the ink is supplied to the head from cartridges.
4. be gentle and do not force the water too much as this will damage the head gaskets.
5. keep in water again for some time and repeat the same process once more but this time do the suction from the same syringe so the dirt can come out into the syringe.
6. Install back the head and do the head cleaning 2 times
And you are done
DO RATE MY SOLUTION
Jul 01, 2011 | Epson Stylus R290 InkJet Printer
Water will not come through the brewing head. I have tried priming it by passing water through the steam pipe as described in the manual and although water comes through the steam pipe it still will not...
Either the screen is blocked or the valve seat is clogged. Remove the screw and screen make sure you can see light through every hole in the screen. Now try to run the head if water flows, screen was dirty if no water, remove 2 allen wrench screws and diffuser and spring and valve(DO NOT LOSE SPRING AND VALVE), run the head, if water flows the blockage is clear re assemble and you are back in business. Here is a little pic to help you on the way.
Jan 16, 2011 | Gaggia Classic Espresso Machine
No water coming through group head
Remove the shower screen and clean. If shower is clean then line to head is clogged.
Jun 18, 2009 | Gaggia Baby Espresso Machine
No water coming out from the shawer head
Welcome to Fixya.com
If I understand you correctly your not getting any water out of your shower head .It could be your shower head is clogged,
or your diverter is bad. Diverter takes the water up to the shower head.
Nov 25, 2008 | Home
Hansgrohe Interaktiv 2-Jet Handshower, Polished Brass  Logo
284 people viewed this question
Top Hansgrohe Home Experts
Daryl Gleaton
Dan Apthorp
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
