Question about LG Electronics Kompressor Pet Care Upright Vacuum Cleaner LUV200R
Lg luv2oor vacuum spits out dirt undernealth vacuum clogs
  • legatormom Mar 27, 2011
    lg lv200r vacuum
    underneath vacuum where the rollers are located
    there is a little square cubby (hole with rubber coating) that is collecting dirt..etc one that gets full it starts spitting out dirt
  • 823 Answers
There is a suction hose in the back on the bottom of the vacuum that connects behind the beater brushes which pick up the dirt from the floor which needs to be checked.
Press the foot release to unlock the vacuum from the upright position and turn it over. Lay it down on the floot in this flat position with the beater brushes facing upwards in plain view.
Pull out all the hair, strings and other debris that are wrapped around the brushes which turn and pick up the dirt from the carpet. Get a pair of scissors if necessary to get everything off of the bar. When the brushes are clean look behind them from the front and see if you can see the tube that is connecting behind the brushes. Can you see debris stuck in this tube? If you can reach it and see debirs there pull it all out to unclog the tube.
If you can't clear or see the debris from this position you may have to disconnect the tube entering behind the brushes and manually pull out anything thats reachable. When its empty reconnect the tube and bring the cleaner to the upright position on the floor.
Empty the dirt collector (whether it be a disposaible bag/filter or a hard plastic cup does not matter) and make sure the vacuum is empty. Disconnect your accessory tube and unwind it. Turn the vacuum on and put your hand over the suction tube for few seconds and then remove it. Keep doing this in a fan like motion to create suction and release it to get everything in the accessory tube to be sucked into the dirt collector. The reason you are seeing dirt come out from under the vaccum is because there is either a clog in the tubes or the bags are being left way over full and no more dirt can be collected.
dirt will come out the bottom of your vacuum when the tube has disconnected, or it has not been pushed in all the way and its leaking out the sides. check to make sure the tube going behind the brush area in the back does not have any leaks. Use duct tape to seal any leaks if necessary.
There are two things that can over heat and ruin a vacuum cleaner. One is failing the clean the beater brushes before usage and the other is not emptying the bag or cup when its full.
Hair and strings get caught in the brushes and restrict it from turning. This causes the machine to work harder than necessary and eventually over heat. People who are unaware of the strings and hair preventing the brush to move freely will notice that the unit does not have as much suction as before and thats about the time they begin to lower and lower it closer to the carpet thinking that "lower" means more suction. The truth is that lower is not more suction at all.
when you leave your vacuum full of dirt it will also cause over heating and eventually ruin the motor.
Try and make it a habit to clear the strings from the brushes before using the vaccum and empty the bag when your finished with it before putting it away. This will save the wear and tare on the machine and can help make it last a lifetime.
Posted on Mar 27, 2011
  • Kandi Cook Mar 28, 2011
    Turn your vacuum on, and turn it over where you can see the brushes. Are they turning? Do the brushes spin when its turned on?
    Brigadier General:
  • 3,513 Answers
Hi
Most probably the hose is clogged.
Please check the bellow link to read detailed information related to your query:-
http://www.doityourself.com/stry/my-vacuum-is-spitting-everything-out-help
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 26, 2011
The vacuum spits out the dirt what is wrong
Lauri,
Most likely, you have a clog somewhere that is preventing the dirt from going to where it is collected in your vacuum and that will usually result in dirt being spit back out.
Aug 13, 2015 | Vacuums
Why is my hoover spirit spitting dirt out the sides?
Hey there! Sounds like you have a clog somewhere in the vacuum. Try removing the hose completely from the cleaner. Use a broom stick to gently loosen and remove any clogs from the hose. Use a wooden spoon to break up and remove any clogs from the lower hose area. Also check that your bag is not full and your brushes are still spinning. Hope this helps!
Jun 03, 2014 | Hoover U5068-900 Sprint Upright Vacuum
DIRT DEVIL SPITTING OUT DIRT
Spitting out dirt usually means there is a clog restricting the airflow.
Jan 14, 2014 | Bissell Cleanview Helix Deluxe Bagless...
The suction will pick up and spit dirt back out on floor
This is an indication that the intake is clogged. Needs disassembly and cleaning.
Charlie
Jan 07, 2011 | Dirt Devil M130100 ''i'' everclean Dual...
What causes a vacuum to make lots of dust and throw back out what it vacuumed
It sounds like the airducts that lead to your dirt chamber are clogged. The dirt can't get through to the dirt cup so it spits it back out and blows dust everywhere.
Nov 27, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka Altima Spitting dirt back out
your intake is clogged at the bottom and your filters are dirty not letting it create suction.is the dirt cup full
Oct 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
My hoover vacuum spits out dirt particles as I vacuum!
the vacuum is clogged somewhere the brush roller is just kicking stuff around, as it cant get into the suction port
Aug 25, 2008 | Hoover S3614 Vacuum
Vacuum
You may have a clog in the dirt inlet by the brush roll, and also the hose.
Mar 18, 2008 | Vacuums
Bissell powerforce
I just got done fixing a unit with this problem. After a bit of time, dirt will build up in the lower unit and clog the vacumm tube. Symptoms: No air flow coming out of the vacuum. Motor is hot. Stuff is spitting out of the front Motor wouldnt start it had over heated. You should remover the roller and clear the clog by hand. Let the motor cool down and it should start once it had cooled down.
Mar 07, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
LG Electronics Kompressor Pet Care Upright Vacuum Cleaner LUV200R Logo
351 people viewed this question
Top LG Vacuums Experts
Think Crucial
Think Crucial
Tim Venetis
Colin Stickland
Colin Stickland
Are you a LG Vacuum Expert? Answer questions, earn points and help others
