Question about Frigidaire FGB24S5A Gas Single Oven
Smelling gas from my Frigerdiare oven when I turn it on.
  • 46 Answers
The pilot light might have gone out, so please do not attempt to light it with a match as gas is
built-up inside the oven. You might want to check the gas supply connection to the oven with a little soapy water to see if any bubbles appear - if so tighten the connection.
Posted on Mar 26, 2011
Amana oven pilot light
If you have a standing pilot and it is not on, you should be smelling gas in the house.
Try lighting it with a BBq lighter directly.
On some stoves, you will have to press a button and hold that button for some time ..over a minute..while you have the light to the middle of the pilot.
Do not proceed to light the pilot until there is no more smell of gas in the oven.
Oct 24, 2013 | Ovens
Whirlpool super capacity 465
Call a gas engineer at once. Gas is extremely dangerous.
Jul 19, 2013 | Ovens
I have a Jenn Air gas oven (range) model JGS9900CDS01. I have been smelling gas only when the oven is on..It seems to cycle from worse to not so as the oven cooks. My repairman just replaced the igniter...
it's still under warranty for 1 year but by him working on it you could have voided the warranty i would call whoever you bought it from or call the factory and tell them it's under a year old what will you do for me.
Feb 07, 2018 | Frigidaire FGB24S5A Gas Single Oven
I can't find the pilot light shut off valve on my Magic Chef oven. Where is the gas shut off valve? It is 20 years old, uni burners with self cleaning oven. 314-837-1073
Good chance there is no shut off for the pilot by its self. Of course one should have been installed at the back where the line comes into the house. If you are smelling gas please turn off your gas until you find the problem.
Aug 16, 2010 | Ovens
This just happened over night the oven is on but there is a bad gas smell when it is in use. There is a hissing noise too.this oven runs on propane
When the burner is burning, are both sides of the burner lit and is it lit all the way down the burner? If it is and you are still smelling gas you should not use the oven until you have it serviced, so you do not have an explosion. Propane is heavier than air, and will settle in low areas, so smell low by the floor around the oven before you light it to make sure you don't have a leak first. To be safe until then, close the shutoff valve on the gas line at the appliance until you get it looked at and fixed. Douglas
Jul 02, 2010 | Ovens
Self clean for 4 hours -- do i need to leave my apt?
The first time you do a self clean it does smell weird and you do not need to do it for 4 hours change the setting to 2 or three hours. This uses allot of ellectricity to do the cleaning. I usually just use a oven clenaing product for light cleanup. If you have a pie that has spilled over or something then it works great. The Smell is a bit of ash and smoke from all the things that you are incinerating inside your oven.
Cheers
Al
Sep 11, 2009 | Bosch Ovens
Oven will not light. burner won't even light if I try lighting it with a lighter. I thought maybe it was the igniter but am wondering if the burners go out on these. This is a problem that has been getting...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
fdfsd
Jun 29, 2009 | Magic Chef 9122 Gas Single Oven
Co smell during oven use
What you are smelling is the protective grease against rust or corrosion that came originally with your oven. the odor is normal if you are just purchase the oven.
Dec 18, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven burner pulsates
The gas regulator valve would also be my first guess. It seems to not be allowing enough gas into the system. When the top is on, only a small amount of fuel is required, and when properly mixed with the air all is well, but when you also put on the oven, the regulator won't allow enough gas into the system, so it's "burning lean". I'd get it fixed before it pulsates so bad that it actually blows out the flames and you're left with a propane smelling dangerous house.
Apr 06, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Gas smell at start up
Be sure that the igniter has a good ground. I mean make sure you clean it well. Be sure its fastened well. And of course that it is close enough to burner. Air flow in building can also hinder lighting.
Nov 14, 2007 | Blodgett DFG-100 Gas Single Oven
Frigidaire FGB24S5A Gas Single Oven Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
