Question about Husqvarna Viking 1
Bobbin? I have a husquvarna viking platinum 955E and the needle isn't picking up the bobbin thread...I've cleaned and rethreaded a million times and the top thread is still looping up on the bottom of the fabric...
    An expert whose answer gotĀ voted for 100 times.
  • 192 Answers
DO NOT RESET THE TIMING!! The timing is off on maybe 1 in 100 modern Husqvarna machines. For the user to change the timing is turning a simple fix into a complicated and expensive fix.
If the top thread is "looping up on the bottom" then you have a problem with the tension on the top thread. Here is what to check:
1. Thread the machine all the way through the eye of the needle. Don't go under the foot.
2. Pull the tread to the side. While pulling, lower the presser foot. You should see the needle bend as the thread gets tight. If not, you have no tension on the top thread.
3. With the bobbin in the case, hold the needle thread and turn the handwheel to bring the thread up. Watch through the cover to see if the thread passes over the bobbin from left to right. When it gets to the right side, the take up lever should pull the slack out and the thread should be pulled up. If it comes part way across but does not pull up, make sure the thread is in the take up lever. If you never see the thread, remove the bobbin case and turn the hand wheel. You should be able to see the hook pass behind the needle while the eye is still below the level of the hook. If the eye is above the hook as it passes the needle from right to left, then and only then consider timing the machine. If the hook passes above the eye but doesn't catch the thread (bobbin case out, needle plate on, presser foot down) you probably have a problem with your needle. Put in a new needle and make sure that the flat side is to the back.
99% of the time when a Husqvarna is not picking up the bobbin thread, something simple has been overlooked. Your symptom of looping on the back of the fabric indicate either a threading or tension issue in most cases, not timing.
Posted on Sep 14, 2008
Why won't it pick up bobbin thread
Try changing the needle--make sure the needle is inserted correctly
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Aug 11, 2014 | Sewing Machines
My viking emerald 118 machine just started breaking needles and the bobbin thread will not hold. YOu can pull the bobbin stitch out by pulling the thread.
Check the upper tension by lowering the presser foot and pulling on the thread through the needle. You should feel resistance. If not, take a stiff brush and clean out the tension disks/dials removing any loose threads or lint. If upper tension is ok, check bobbin tension by pulling thread through needle plate opening. You should feel resistance. If not, remove bobbin case and brush any loose threads or lint from the case, especially in the tension spring where the thread is snapped into place. You may need to use a sharp needle to dig in between the spring but be careful that you don't damage it.
Jun 17, 2014 | Husqvarna Viking Emerald 116 Sewing...
The bobbin isn't catching on my Viking Husqvarna 190
Your machine is out of time. You'll need to take it in to a professional to get it timed correctly
Nov 24, 2012 | Sewing Machines
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
I have been sewing all day with no problems. Suddenly the needle is not picking up the bobbin thread. Why? Solution? Thanks!
the needle might be bent-roll needle on flat surface & see if it rolls correctly
if the needle is make a popping sound when it goes thur fabric the needle is blunt
check the bobbin area to see if there is lint or loose thread
check to see if the bobbin has become warped
the bobbin may not be inserted correctly in the bobbin case
check to make sure the bobbin case is inserted correctly into the machine
rethread the sewing machine in case the thread is caught somewhere
make sure there is a thread tail of 3-4 inches on both upper thead & lower thread
Sep 02, 2010 | Husqvarna Viking 1
Needle does not pick up thread from bobbin
rethread the bobbin and/or check the bobbin is placed correctly, rethread upper thread
Feb 11, 2010 | Sewing Machines
Thread breaks
Check to see if the lower thread be tangled. Also, the bobbin could be threaded improperly in the shuttle hook. Rethread the bobbin in the shuttle hook.
How to detangle a thread---
  • When a machine stops operation due to tangled thread, do not turn the pulley by force.
    If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly.
  • If threads get tangled, remove a needle plate and cut the tangled threads by scissors or cutter.
  • Do rate the solution if you find it helpful & useful.
    Jan 30, 2009 | Husqvarna Viking 1
    When threading my Viking sewing machine., the needle won't pick up the thread. used it 15 years. This is the 1st time this happened. Help...
    Do you mean it wont pick up the bobbin thread? You need to get into the user's manual on removing the bobbin shuttle that the bobbin holder clips into (actually pretty easy, I clean ours yearly especially if fuzzy material like velour is sewn) and brush the fixed area out that the bobbin shuttle floats in then reassemble and test. Also remove the throat plate/needle plate and you'll find that fuzz/lint gets between the plat and the feed dogs keeping the dogs from coming up fully.
    Also if thread breaks one thing to look for if you've had needles break is a burr around the oval opening in the plate where the needle goes into it. Small Swiss file takes care of the burr and no more burr to break/cut the threads.
    On rare occasions you may find the actual bobbin carrier (the one that holds the bobbin and is clipped into the machine) gets worn and wont stay clipped into the shuttle that holds it. Replacing the bobbin carrier is needed then. A1 Sewing on the net carries parts for the #1, #1+ etc.
    Apr 26, 2008 | Husqvarna Viking 1
    Sewing Machines Logo
    258 people viewed this question
    Top Husqvarna Sewing Machines Experts
    Douglas Plant
    Douglas Plant
    Tally Girl
    Tally Girl
    Wayne Fellows
    Wayne Fellows
    Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
