Teac hdb840 stbox/55" philips rear projector tv
I have connected these by component out and vga in using supports 480p/1080i at 60hz and 576p at 50hz. i dont know the output signal for stbox.with this setup and after all nessessary adjustments i am only able to get a 576p resolution on my tv.what do i do to get a 1080i resolution on the monitor?
  • 2,071 Answers
How do i connect my dvi to vga to my misubishi ws-65313
you can't, DVI is a digital video source and VGA is an analog video source. however there is a VGA to component RGBHV cable that you can use. the Mitsubishi TV is very limited to the resolutions the VGA output can be. only 1080I, 480P or 480I. HD component video input in the menu you must change the source from Y /Pb/ Pr to RGB.
Jun 07, 2014 | Mitsubishi WS-65313 65" Rear Projection...
480p to 1080i
Your TV should automatically switch to 1080i if the source input is in 1080i format. Also, since your TV does not have HDMI, you must use the component 1 or 2 inputs (using component cables) for 1080i source material. You cannot get 1080i from composite or s-video inputs. You should be able to switch to the component inputs using the remote or the front control panel using TV/Video button.
Sep 02, 2012 | Panasonic PT-47WX42 47" Rear Projection...
Runco DTV-5800-component to BNC connection problem
component cables have standard RCA fitting on the end. you can however but adapters enc to RCA. these work well are are readily available through eBay
May 04, 2010 | Runco DTV-5800 58 in. Rear Projection...
Double lettering on red when in 1080i good picture in 480p
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
Sep 06, 2009 | Philips 55PP9401 55" Rear Projection...
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Setting 1080i
Component inputs 1 and 2 will only pass up to 480p. to get 1080i you must use the DTV component input.
Dec 07, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Connecting PS3 to Mitsubishi WS-55809
On the back of the TV you should find three sets of the component sockets, only one can produce 1080, the one that is labeled dtv (should be the one on the farthest right of the three sets).
May 13, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809
Looks like you are going to be working with the following:
1080i (HDTV) • 480p (EDTV) • 480i (SDTV)
Hook up depends on what else you have connected to the TV.  If you have nothing connected to the DTV component inputs, I suggest using those, as it will allow up to 1080i.  Otherwise, use the 2 other component connections directly to the left of the DTV connections.
Oct 19, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WT-46809 Problem getting HD from DirecTV
I have the same exact problem. Same model, etc. Is there a resolution?
Sep 16, 2006 | Mitsubishi WT-46809 46" Rear Projection...
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
