Samsung LN32B360 32 in. LCD HDTV Logo
Posted on Mar 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scart leads don,t go in to back of tv - Samsung LN32B360 32 in. LCD HDTV
alexander woolfolk
Level 2:
Guru:
  • Expert 276 Answers
  • Posted on Mar 26, 2011
alexander woolfolk
Expert
Level 2:
Guru:
Answers
276
Questions
Helped
110167
Points
753
The Samsung HDTV you refer to is a North American model and is not designed to accept Scart (European) connectors. However, you may be able to connect your component by using a Scart to RCA adapter. This will allow a Scart component to connect to the HDTV if you get the proper adapter with yellow video and white and red audio RCA connectors which will indeed plug into the HDTV. Look around on the web for cables and adapters like the example here:
http://www.svideo.com/scart.html
It would look something like this:
1 Related Answer
Anonymous
  • 135 Answers
  • Posted on Apr 13, 2010
SOURCE: will using a gold hdmi lead as opposed to scart improve picture
only on the hd channels
Got a double picture on my TV which is going through a bt u view box
If you are not getting a tidy pic first thing I would check or change is scart lead make sure they are firmly in back of TV and your viewing box if so try another scart lead, the thicker the scart lead is the better they are apparently. Or if your using hdmi lead instead of scart try another hdmi port at back of TV as these ports tend to break easy in TV as they break off the mother board.
I have a THS220 box and have difficulty recording programmes
Hello Joan,
To record a satellite you will need two scart leads.
Plug one end of the first scart lead into the "DVD/VCR SCART" socket on the back of the satellite receiver, then plug the other end into the "INPUT" scart on the back of the VCR. Take one end of the second scart lead and plug it into the "OUTPUT" socket on the back of the VCR and plug the other end into "SCART IN" socket on the back of the TV.
To record, select the satellite channel you want to record, then, on the VCR, select scart input, (at this point, you can record a satellite program). To watch a satellite channel or recorded satellite channel, select the scart input on the TV.
If you need anymore information, then let me know.
Kind regards,
Ron.
Directions for plugging your 4head hi fi stereo ito your tv
You don't really say what make or model is the TV or VCR. However if you have a TV with a scart socket you can get a scart lead and connect the VCR via that. If the VCR has two scarts connect it via AV1 sometimes black whereas the other might be blue. If the TV has more than one you will have to try each one, unless it says VCR on the scart socket, till you get the best picture.
How do I record on my magnavox dvd/vcr if I don'' have a set-top box?
The only thing you can do is connect a scart lead from the VCR to your TV and set the VCR on the aux position of the scart socket.
You can only watch the show you are recording though.
If the TV has only one scart socket and you are using it for something else. Then I suggest you get one of these:
When i plug my new tv into the sky box via a scart, the tv picture is distorted and a major buzzing noise is coming from the tv. sky have checked and said the box is fine. when u connect to another tv it...
Have you tried another scart lead? Also tried all of the tv scart sockets? Don't try and cure this by using an expensive upmarket scart lead, you'll just be wasting your money. The cheapest leads work just as well when the function correctly.
You could also try reversing your current lead by swapping the tv end to the Sky box and vice-versa, as there are many leads which cause feedback issues, and also a lot of "cut" leads (designed to prevent feedback looping) which must be fitted the correct way around. A "cut" lead is one where the wire to pin 19 at the tv end and to pin 20 at the video/Sky box end has been cut.
Note that scart leads MUST be fitted with the tv and Sky box switched off to avoid damage. Most people (including professional installers) regularly ignore this precaution though.
If all else fails then take the tv back and exchange it under the Sale of Goods Act; it's certainly not uncommon for new tv's to have faulty scart sockets.
If I've solved your problem then please take a moment to rate my answer. If not, then please report back with the make and model of TV and I'll try a more specific answer.
TV/DVD combo does not work with Freeview box
check your scart leads for pins damage.
Replace scart lead or try another one
AndystUK
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
2helpful
Connecting a dvd 250gb hard drive recorder to tv and virgin box
Right then, on the back of the virgin box there are 2 scart outlets, connect one scart from the TV scart port to the scart in on the DVD recorder, then connect one scart lead from the scart out on the DVD recorder to the TV.
Find the DVD recorder source channel on the TV and then use the DVD remote control to find the digital input on the DVD recorder, this is usually AUX channel.
Post back if you need any more help
Good luck and thanks for using Fixya!!
1helpful
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
LOOSE SCART
Theres no way to tighten this as its gonna need to be resoldered and you must have experience working on tv sets due to the hI voltage issues here. If you take it to your repairman now hopefully its not to late and can easyley be repaired. Good Luck
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
