Question about Uniden Cordless Phone
I just bought a uniden DWX207, didnt think that it was registered to bases so cleared it and now it wont register to its base...i followed all the instructions to register it again and it tells me that the attempt has failed...its the yellow waterproof one
  • 2,382 Answers
Hi, this is an unusual problem on a new phone. Could possibly be radio frequency interference close by.
Some cordless phones operate on the same frequencies as in-home wireless networks. I believe this is the 2.8 megahertz frequency. The phones and the wireless networks can interfere with each other.
Most newer cordless phones are higher frequency (5.8 megahertz?). Wireless networks shouldn't interfere with those phones, but there could be other things that could (e.g., transformers on power poles).
If the phones are new, you might consider taking them back and getting another model.
Posted on Mar 26, 2011
Uniden dwx207
When a handset is reading "Searching", it can't communicate with the base. First, check if the base station is plugged into a live outlet. (Try plugging the base into a different outlet or making sure that the circuit breaker hasn't popped. I had a cordless phone base plugged into a UPS. During an extended power outage, the UPS was turned off. The phone didn't work until someone noticed and turned the UPS back on.) Move closer to the base station.
If this was an extra handset purchased later, make sure it is compatible with the base station. The Uniden DWX207 works with the DECT1500, DECT2000 and DECT3000 series bases. Register the handset with the base. The registration procedure depends on the base station. If the base unit has an LCD screen, with the phone in standby, press Menu/Select and press the down arrow to reach "Register Handset". Then press Menu Select again. (If the base doesn't have an LCD screen, unplug the power cord. Then hold the Find HS or Find button as you reconnect the power cord until the Charge/In Use light starts to blink.) Then press the # key on the handset before the registration period ends.
Make sure that you haven't exceeded the number of handsets for your base. You may need to de-register all handsets and then re-register them.
If no handsets will pair with the base, replace the base unit. The transmitter or the receiver aren't communicating properly with the handsets.
I hope this helps.
Oct 06, 2013 | Lands Phones
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
Uniden registering
Follow the registration instructions beginning on page 5 of the DWX207 manual at http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DWX207om.pdf
May 15, 2013 | Uniden Cordless Phone
HOW DO U CONNECT THE HANDSET TO THE BASE.ALREADY TRIED THE REGISTER BUTTON,DID NOT WORK.IT CAME WITH NO DIRECTIONS,WE BOUGHT AT A FLE MARKET FOR 5 DOLLARS.
Are you sure of the model number? The D1680 should register the handset when you put it on the base for 30 seconds. (You should see Handset Registering followed by Registration Complete.) Then press Talk/Flash to check for dial tone. On this model if the registration fails, charge the battery (or replace the battery and then charge that). Then repeat the registration.
The manual for the Uniden D1680 is available here: http://news.uniden.com/pdf/D1680om.pdf .
For other Uniden phones, like the DEC1060, you need to navigate through the handset menus to find the Handset Registration command. Then press and hold the Register Handset (Find Handset) key on the base for 3+ secondsThen the base and handset will synch. (Low batteries could interfere with the process.)
For the D3288, you access the base menu for Register Accy and then press and hold # on the handset for 30+ seconds. (You will see Registering followed by Registration Complete.)
Additional Uniden cordless phone manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl .
I hope this helps.
(with a flea market phone, my first suggestion is to try a new battery for the handset. They only have a given number of recharge cycles and you do not know the history. However, sometimes the chargers do fail and a new battery will not work. In that case, the phone should be replaced. It isn't worth the cost of out-of-warranty repairs.)
Jul 01, 2011 | Uniden D1680 Cordless Phone
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Nov 12, 2010 | Uniden Lands Phones
ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Aug 02, 2009 | Uniden DECT 6.0 Cordless Telephone...
Redistration to other brand DECT 6.0 base failed.
DECT 6.0 IS JUST A MARKET NAME FOR DIFFERENT BRANDS, THE WATERPROOF DWX207 WILL ONLY WORK WITH UNIDEN PHONES, ONLY BECAUSE YOU WANT THEM TO WORK TOGETHER DOES NOT MEAN THEY WILL WORK TOGETHER...
May 22, 2009 | Uniden DECT 6.0 Cordless Telephone...
Cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Apr 25, 2009 | Uniden DECT 6.0 Cordless Phone ID
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
Resetting the Handset
YOU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
SYSTEM RESET menu
appears.
2. Select the DEREGISTER HS
submenu. WHICH HANDSET?
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
appears. CHOSE A NUMBER THAT IS NOT ONE OF YOUR WORKING HANDSETS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
PUT THE HANDSET IN THE BASE CHARGER AND IT SHOULD REGISTER
Hope This Helps - It worked for me
Dec 29, 2007 | Uniden TRU9488 Phone
Uniden Cordless Phone Logo
56 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
