Question about John Deere Garden
I have a John deere 214 lawn tractor that has no spark while cranking over but gives off a spark at the release of the key?
  • crashfirejoe Mar 26, 2011
    No it is points and condenser. It is not a battery issue. It has a new battery and have assisted with a jump due to draining trying to figure this out.
  • 8,841 Answers
Hi, this sounds like a wiring or starter solenoid issue. Do you have the 4-terminal solenoid? If yes, is there a wire from one of the smaller terminals to the ignition coil positive terminal? If yes, try moving that wire from the small solenoid terminal to the large terminal that connects to the starter. This will ensure that 12 volts goes to the coil when the key is turned to start. If this works, you may want to get a new solenoid.
If you don't have the wire I'm talking about, you probably have a problem with the wire from the ignition switch to the coil. You can still add the wire I have suggested from the starter terminal of the solenoid to the coil, and this will power the coil.
Please let me know if you have questions and thanks for using FixYa.
Posted on Mar 27, 2011
  • Jeffrey Turcotte
    Jeffrey Turcotte Mar 27, 2011
    If none of this works, the problem may be with the points not opening or shorted closed. Check to make sure the wire from the points is not grounded or has it's insulation peeled/melted and that the points do open when the engine turns.
  • 4,350 Answers
Do you know if you have electronic ignition? On some types, the voltage vailable during cranking is too low to fire off the ignition, then you release the key and there is enough....to test for this issue, jump the unit from another vehicle.
Motorcycles with electronic ignition have this issue and must have perfect battery state of charge to actually allow enough current to operate the electionics...
Posted on Mar 26, 2011
What size belt goes on john deere 214 deck
Go to Google type in John Deere lawn tractor model number then owners manual
Jul 08, 2017 | John Deere Garden
How to I remove the steering wheel from SX75 John Deere riding lawn mower
I have not been able to pin down your exact model but this link is to another model that may give you the info you need. john deere 214 steering wheel removal
Oct 17, 2016 | John Deere Garden
No spark while cranking,only when you turn the key off?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
John Deere 316 318 and 420 Lawn and Garden Tractors Service Manual
Dec 05, 2015 | John Deere Technical Service Repair Manual...
I have JD 214 that I've replace coil, points spark plug,wire yet still getting no spark the mower just quit run inspection I found that the points was burnt and plastic where power attached was melted
Wow, a tractor with points. That's rare these days. I believe your tractor was made between 1975 and 1987. It's a 200 series. Does it have the 14 hp Kohler?
Not sure about your problem. On a modern day tractor with electronic ignition, I would check the safety switch system. In your case, I would check the fuse, key switch, and look at the kill wire running off the coils to see if there is worn insulation. If you have seat safety or PTO switches check them too.
You can get parts here:
John Deere 214 Lawn and Garden Tractor Parts
Apr 16, 2015 | Garden
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
Apr 21, 2014 | John Deere Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
No spark
did you make sure the gap was set right on coil & flywheel it should be .020 between magnet on flywheel & the coil & the same thing with the points in the open possition between points & condensor
Jun 07, 2009 | Garden
John deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
May 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
306 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
