Question about Saeco Gran Crema Espresso Machine
Push on, click to coffee: it's green. But the coffee enough doen't descend.
Water not dispensing
new installs require one to hold down the dispense button sometimes as long as 3 min to allow the water to make its way thru the filter and lines and allow the air to get out , also if you have a well , I have run across one that didn't have enough pressure to push thru the filter when it was new ,as it takes at least 40 psi to push thru a dry filter when its new , it doens get easyier when its wet
Mar 17, 2016 | Refrigerators
Why can't i get cup size in capresso impressa?
Hold the button in, until it says "Enough?" then release..
When you have the right amount, push the button again.
Jul 06, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
DeLonghi Magnifica 3200 how to increase coffee temperature?
Evening to you
Not hot enough, do you leave it to stand with the green lights on?
By my experience the machine is best left on so everything is hot when the water passes through.
To let some time pass before you make the next cup.
And lasly to make sure that machine is clean.
Good luck
kolbrun
Mar 05, 2012 | Faberware FSCM100 Coffee and Espresso...
We are attempting to use the LA3 by pouring water into the top of the machine as opposed to auto through a water line. The water heats up, the green ready light comes on, I push the start button and it...
If it is not connected to a water line then you cannot use the hot water faucet or the start/brew button, you will have to manually brew coffee by pouring the water into the reservoir.
Nov 16, 2011 | Brewmatic LA3 Coffee Maker
It doen not turn on completly. The green light blinks about every 5 seconds but doesn't turn on.
it is not getting enough power. Use a two ended USB plug (both ends into computer) one into HD, or use external power adapter
Jul 10, 2011 | Western Digital My Book Essential Edition...
Won't pull up water from the reservior to the coffee carafe.
Your heating element is plugged. The element gets water but not enough to build up enough pressure to push the water up to the drip head, when that happens what it will do is steam a little, overheat and shut off. I pulled a wire through my element got a lot of **** out now it works like new.
Jul 30, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
I have a Saeco Magic Comfort Coffee machine. The digital display says "Ventalate". What do I do?
Hi There is a push button for water. Its the one that looks like a drop of water. This is what needs to be pushed. You don't open any knobs on a MC+. If nothing comes out when you push listen for a click of a solenoid. You should hear that click. If you don't hear the xclick you have a stuck solenoid. This is usually caused by not descaling enough. Set you water hardness to 4. Always push the "enter or menu" button after making a change to lock.
Jul 28, 2009 | Saeco Magic De Luxe Espresso Machine
One cup brewer, says it is brewing, but the
If the brewer heats the water but it doen not dispense this is probably because air is trapped in the tubing of the water system.
To solve, use as air compresser with minimum pressure (20-25 psi) and force air through the system using an air nozzle that is long enough to reach into the hole into the area where you fill the water. Place your hand under the dispenser and ensure you can feel the air from the compressor coming through.
Once you clean out the lines, you should be good to go.
We have had our coffee maker sitting on our shelf "broken" for months now. We tried this last ditch effort before tossing the machine in the trash and low and behold it worked! :)
Apr 02, 2009 | Keurig Platinum B70 Coffee Maker
Saeco Gran Crema Espresso Machine Logo
23 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
