Below will tell you about the part...what may be wrong with the part and how to check the part. From the service manual. Sounds as if the lid lock mechanism is broken. Lid Lock Mechanism-Since this washer does not utilize a brake, a lid lock is used to prevent access during the spin cycles. During the drain and spin portions of the cycle, a lid lock mechanism will lock the lid. The lid locks are based on cycle phase. In general, the lid locks when the basket spins greater than 23 rpm. After main wash, the lid is locked, and remains locked until the end of the cycle. The lid must be closed for the machine to fill, wash, drain, or spin. Magnets in the washer lid close a reed switch in the lid lock. This acts as the "lid" (Lid Opened) Is the lid open? Is the lid open? The lid must be closed during operation. The washer will not operate with the lid open. How to remove the lid lock mechanism to check and or replace. To remove the lid lock: a) Raise the cabinet top (see step 3e page 4-4 for the procedure). b) Remove the two hex-head screws from the lid lock and remove the lock. c) Cut the indicated cable standoff from the cabinet top. d) Unclip the lid lock cable from the cabinet e) Disconnect the lid lock cable connector from the machine/motor control connector at P12. f) Pull the end of the lid lock cable from the control, and remove the lid lock and Check the lid lock motor winding and switches by removing P12 from the machine/ motor control, and checking the resistance values shown in the following Lid Lock Resistance table. - lock switch home 0 open circuit p12-4 Lock Switch - lock Lock Open Circuit 0 ? P12-7 Lock Switch -Lid Lid Open = Open Circuit P12-5 If resistance values are good, go to step 6.If switch measurements do not match the values shown in the table for unlocke (or locked) conditions, a problem exists in the door lid lock. Replace the door lid lock. 6. If the Manual: Door Switch or Manual: Door Lid Lock tests in step 1 failed, then the machine/motor control has failed: Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock tests in step 1 to verify repair. If you need further assistance please post questions.
lid switch.
Close the lid to clear the display.
top flange.
cable assembly from the washer
Lid Lock Connector P12
How to check the lid switch/......resistance chart
Resistance locked or unlocked Contacts measured
Motor Winding 35 ±5 ? 35 ±5 ? P12-2 P12-3
Thanks
