Question about Mitsubishi WS-55807 TV
Click, no pic.
I am getting the click, light for 3 seconds, click.
both the F9A04 and F9A05 fuses are closed (solid color with no visible break) i am scanning the whole thing and i can't find a break at all. I followed the click to something, but that only made me confused seeing as i have no idea what it is. P765-1. I have experience with electronics (I work on electronic paintball guns as well as my own and friends computers) I believe I am in a little over my head and would greatly appreciate your help. if you could contact me through my e-mail ( correspondence would be much easier.
Thank you in advance,
  • 927 Answers
Good Day, Jacob;
Jacob I'm glad to hear that you are an experience tech. and since you are try this:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Posted on Aug 07, 2008
Won't turn on
The five amp fuses are very fast acting pico fuses, by design.
You say you replaced both convergence IC's or not?
Let me know....T.
PS What quality,price and part # IC's.....?
Dec 19, 2007 | Mitsubishi WS-55807 TV
I just replaced the 2 ic chips (stk392-570) and the 2 pico fuses at f9a04 and f9a05 that were blown. The tv powed up for about 10 seconds then turned off again. Now i'm getting the same 3 second power...
You have bias resistors close to the IC's, I would guess you have a few that have changed in value and therefore have destroyed the IC's again. Now you must start over again. The resistors will be very low Resistance and tolerance and they must check exact.
Jun 04, 2009 | Mitsubishi WS-55809 55" Rear Projection...
did you replace the tw0 5 amp pico fuses F9A04 and F9A05 as they usually open when an IC fails
Jan 24, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55819 Won't turn on
If F9A04 and F9A05 are open the convergence ICs will need to be replaced as well as the two pico fuses. You will need two STK392-570 Convergence ICs and two 5 amp pico fuses. You ca get the replacement parts at the following link with free installation instructions. heres thelink.
Jan 22, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-65908 Error Code 24
If you have an ohm meter, check the resistance from F9A04 to ground, and then reverse the leads and check F9A05 to ground. These supply +24 and -24 to the convergence integrated circuits. The conv ic's may be bad. Also, code 24 usually indicates vertical deflection failure as well. One other check to make.....The pic tubes on this set may leak a few drops of coolant onto the boards. Look VERY carefully for liquid drops on the boards or a green and or white corrosion spot or two on the boards under the pic tubes-near the front of the chassis.
Dec 12, 2008 | Mitsubishi WS-65908 TV
Cant tune red bulb
Check pico fuses F9A04 and F9A05 if either one of those picos are open it means the convergence Ics are bad along with the picos. Your set uses two STK392-570 ICs and the two picos are both 5amp picos. You can get replacement parts and installation instructions at the following link.
The pico fuses are located on the second board from the right heres a pic of where they are.b86c4db.jpg
Nov 25, 2008 | Mitsubishi WS-65809 65" Rear Projection...
My big screen tv
Those are the two 5amp pico fuses that go out when the convergenec Ics go out on a mitsubishi. You can get the ICs and pico fuses at the following link. If youre not sure which ICs you need leave them a email with your model nuber.Heres the link
Sep 01, 2008 | Televison & Video
I've got the blinking lights also. Model # WS-55613. Does anyone know what the problem is?
Dec 27, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 Will Not Power On
first off you should replace both convergance IC and check the resisters coming off the output if any of the resisters are bad it will trash the ic on trying to power up.
i would also replace the caps in the DM section
Mitsubishi WS-55807 TV Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
