Question about GE Refrigerators
GE 23.5 Model # TFF24RC Makes Noise, Won't freeze, center post gets very hot.
  • Sean Miller Mar 26, 2011
    Hi what is the age of the unit?
    Sean
    Scholar:
  • 116 Answers
If this is an older unit, take the rear panel off and check the condenser coils in the back on the back of the refrigerator, and check to see if the fan is running back there or if anything is block the fan from running, if nothing is blocking it and its not running this is a bad condenser fan, if it is running check to see how dirty the coils are, if they are really dirty take vacuum or brush and clean them should fix your problem.
Sean
Posted on Mar 26, 2011
My Electrolux EW23CS65GS1 model JCD-23 the freezer makes a strange noise at the rear it sounds like it comes from inside what is it and what can I do?
Thanks for your post, Rob Muzich!
From the information you have provided your Electrolux refrigerator is making a strange noise at the rear. Depending on what type of noise you are hearing it could be a normal operating sound. In the manual it provides a list of sounds on page 23. I have included a digital copy of the manual for you to review. If you need any additional assistance please feel free to reconnect. -Matt
Frigidaire Manual Search Results
Nov 28, 2014 | Electrolux Refrigerators
GE Washing Machine WWSE6260B1WW won't spin out water makes a rattle noise
use a putty knife to remove the front panel , you can remove it by pushing the putty knife into the 2 black tabs between the top and front panel. from there you can get to the drain pump . inspect by taking the hoses off the pump and remove debris. If nothing found replace the pump. hope this helps, let me know
Feb 19, 2013 | Washing Machines
My compressor is very hot and not running or kicking on, it was making a load humming noise yesterday and my freezor is not freezing?
It is cycling on overload and not starting. you can try a "hard start kit". If it still won't start then the unit must be replaced
Jun 24, 2011 | GE 18.0 Cu. Ft. Frost-Free Top-Mount...
Dryer makes a loud squealing noise
the rear bearing is gone,ge has a bearing kit that goes on the back of the drum and hooks onto the back wall,the bearing wears down and gets noisy,call your parts store,give them the model number and they'll give you the parts you need
Dec 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Our ge fridge is freezing food all over the lower fresh food compartment and the fan makes noise occasionally. does the fan need to be replaced?
the freezing on the lower fresh food area is some times caused by the freezer cold coil freezing up also caused fan noise .( that is where the fan is located . ) the heaters and tefroat terminator need too be ck and repalced if bad ..mm hope this helpt mm feed back pls ..
Nov 08, 2010 | GE Refrigerators
Sides of the refrigerator get extremely hot
The coils below fridge need cleaning very badly ( if G E then behind fridge) or the fan behind refrig which cools the compressor , is not working . Model number would have been helpful .
Aug 12, 2009 | GE Refrigerators
Loud noise like tray vibrating. does not cook.
Call GE answer center 1-800-626-2000 ask for tech help, Have your Model # orr your data plate ready.
May 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
Groaning noise on GE side by side refrigerator
Usually the groaning noise is from a locked up icemaker. Remove the icemaker and defrost it with hot water. Check to make sure the unit is in good shape and not chipping. Let it dry out and then reinstall.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_e97a69269ae71345
Jan 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
191 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
