Question about Siemens SL5A70UC 24 in. Built-in Dishwasher
My dishwasher SL34A015UC / 29 does not complete it's cycle. The cycle will stop with 1 minute left in the rince cycle and continue to run for hours, showing just one minute left. The dishes are not geting clean and there is a unplesent odor inside. I can hear the water draining during the cycle. The drain line is clear and there is plenty of water in the dishwasher. Any thoughts?
  • 30 Answers
SOURCE: Dishwasher
Check to see if you have any switches on your dishwasher that could by pass a rinse cycle. Use a hotter temparture when washing, Check your water level,check your filters on your inlet hose top and bottom. When it gets to a rinse cycle you should hear it drain out and bring in fresh water. you could change to a liquid detergent. Dont over load your dishwasher. make sure you are using rinse aid and try adjusting it up one setting. Shiney glasses means your rinse add is working. NZL
Posted on Jan 05, 2007
  • 10 Answers
SOURCE: dishwasher takes too long
first thing to check is the connection from the drain hose to the spigot under the sink. in most cases food accumulates there because the hole inside the spigot in not drilled all the way around when the d/w is installed and a "lip" is left where the food stacks onto. if clear check for a kink in the drain hose at the back of the d/w and all the way to the sink. if ok then time to check the drain pump.
take care.
Posted on Jul 22, 2008
  • 116 Answers
SOURCE: Not starting wash cycle
Typically this means that there has been a water leak of some sort and there is water in the lower base pan. This is the large white plastic base that the dishwasher sits on.
If you remove the toe kick and look back past the fill valve on the extreme left side of the dishwasher about 6 to 8 inches from the front you will see a red stick that goes straight up and down. This is a mechanical linkage that activates the drain feature. Be careful as there are live connections here.
This stick rests on a round piece of Styrofoam that acts as a float. If there is water present it will cause the stick to lift and the dishwasher will go into drain. The source of the leak will have to be isolated and corrected. Most likely it is the fill float assembly as referenced at the end of this post.
If the stick is not in the upright position then there is possibly an issue with the switch mechanism itself.
You will have to pull the dishwasher out from beneath the cabinet and remove the panel covering the left hand side. If it is a full panel then there are a couple of screws holding it on from the front through side trim as viewed when the door is open if it is a half panel then it can be removed by removing the large torx screw on the lower right as seen when facing the panel.
If there is a problem with the switch then the entire mechanism should be replaced.
Try the following link to a picture for reference. It is upside down as compared to the installed one:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=935595&PPStack=1
Posted on Sep 17, 2008
SOURCE: Dishes are not clean; lots of soap residue
Try the combo liguidgel powder packets and wash on the potscrubber plus setting. We saw a drastic improvement with this setting. I have just about gotten out of the habit of thorough pre-washing, but I do rinse heavily soiled items.
Posted on Nov 25, 2008
SOURCE: kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Posted on Jan 02, 2009
Frigidaire FFB240 dishwasher won't stop
Good Morning AA1970,
I see that you are having trouble with your Frigidaire dishwasher, model# FFB240, continuing to run unless you shut it off. While I'm not familiar with this particular model number, I suggest that you give the appliance a hard reset. You will do this by shutting the power off at the circuit breaker for at least 20-30 minutes. After restoring power, run the cycle. If it is still continuing to run unless you shut it off, I suggest contacting a local authorized technician for further assistance.
-Best Regards-
WP
Apr 01, 2014 | Frigidaire FFBD2406NS Built In Dishwashers
Dishes not cleaning after full cycle running
Your screens are plugged with food residue in the bottom of the unit. clean it out. You can use 1 gallon of white vinegar for your wash after you clean the screens. Start your washer to fill with water but after the water starts, open your door and pore all of the gallon in the unit. Let it now run for 4 minutes and stop it by opening the door. Leave the door slightly open for 1 hour. close the door and let the cycle continue for 4 more minutes. open the door and repeat it a couple of more times. Let it sit all night with the vinegar in it and in the morning - close the door and let the cycle continue to the end. This should help soften and clean out the food particles in the unit. You can repeat the process and get a better cleaning then too. All the scale should be off your dishes now.
Jan 08, 2014 | Frigidaire Professional Series 24 in....
NEFF S5443X1GB/29 My dishwasher isn't completing it's full cycle. It seems to be washing ok, however towards the end of the programme instead of going quiet whilst drying and then gurgling quickly and a...
Does the drying occur? If the heaters are not working it may need the temp to be high this may stop it moving to the next part of the program ?
Nov 02, 2013 | Dishwashers
Gu 120 es
there is a "smartclean" sensor that measures dissolved solids in the water in an attempt to shorten the washing cycle. however if the dishes have much food left on them, then the washer will continue to run untill it gets a "clean" reading, or it reaches the max run time (180 minutes). all energy star dishwasher require the dishes to be throughly rinsed before washing in the machine. trust me, i know how counterproductive this is.
Sep 26, 2013 | Whirlpool Dishwashers
Does not complete rince cycle
1) Test the heating elements, it is defective will not, will not heat the water and the machine stop.
http://www.youtube.com/watch?feature=player_embedded&v=lZCP55aScvI
2) Tes the timer see the diagram attached.
May 07, 2012 | Kenmore 24 in. 15252 / 15254 / 15259...
Hobart sr24h; It is doing a double cycle; runs a compleat wash and rince cycle stops then 30 sec later start over so our normal 3 min clean now takes 7 min to fully stop operating. What could be the cause...
Thats easy....Change your timer !! The timer turns 180 degrees for one cycle .Then 180 degrees for another cycle thus completing a 360 degree rotation . One side of the timer appears to be broken.
Sep 17, 2011 | Hobart SR24-H Built-in Dishwasher
Dishwasher continues to run beyond necessary time
most likely the microprocessor has failed
Good Luck!
Feb 20, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool gold dishwasher gets stuck at 53 minutes left for an hour
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Nov 08, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Cycle runs for 2-3 or more hours
If your dishwasher's cycle times are too long, check these: Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing f the cycle doesn't complete, check these:
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Oct 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Siemens SL5A70UC 24 in. Built-in Dishwasher Logo
154 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
