Question about JoWood Productions Transport Giant Gold Edition for Windows
Transport giant gold will not fit into monitor screen e.g. buttons unclickable because not visible
64 bit interactive
Change the startup shortcuts properties so that it runs in compatibility mode for windows XP.
Dec 16, 2013 | JoWood Productions Transport Giant Gold...
Black color screen
Change your screen resolution to the highest setting first, in control panel, appearance/ themes. Next Push smart button on bottom right of monitor. Cinema mode should be highlighted hit autoset on monitor. Next hit the FUN button and highlight the 4:3 screen setting. This will expand your image to fit the screen without giving it that stretched and distorted appearance.
Jul 18, 2010 | LG W1953TPF 19" Monitor
1920x1080 resolution-entire screen not viewable
This also happens to my vga connection to my TV.
I used my tv remote "auto" button to re-size it to fit correctly.
If your monitor/TV does not have the adjustment, you may need to
supply your vga compatible device with your monitor's driver software.
This tells your computer what monitor specifications you have.
Mar 16, 2010 | ViewSonic X Series VX2260wm 21.5"...
White screen on lcd nothing visible but output ok
i think you should try Fn-F5 not F6 hold the button down a while
Dec 21, 2009 | ASUS Eee 4G Notebook
Images appear stretched verticley. How can i adjust?
comtrol panel - display - settings - unclick "strech to fit"
Oct 08, 2009 | NEC-Mitsubishi AccuSync LCD72VX 17" LCD...
My screen suddenly goes black and nothing is visible anymore..and when i restart then too after sometime same happens
check the RAM of your computer... try to disconnect it to the motherboard and then wipe the color gold a piece of pencil eraser... then connect it again.. turn on your computer..
Aug 29, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Only approx. 4'' of visible screen rest of screen gray
adjust your screen resolution until it fits as you have the resolution higher than the native reolution of you monitor
Mar 30, 2009 | Computers & Internet
The viewable area is bigger than the screen. I
You probably need to go into the control panel and change the resolution for your display
Mar 12, 2009 | ViewSonic VP920b 19" LCD Monitor
Intermittent monitor outages with MPC Transport T1200? Should I replace monitor or check wiring and how? New-to-me laptop, upon powering on no picture was visible, could hear all normal sounds of...
Looking through your owners manual, there are several keyboard shortcuts that can at least increase the appearance, although it sounds like a simple connection problem. Very hard to find a repair manual, although most transport laptops have a very thin multiwire cable connecting the monitor to the keyboard. Sounds like that cable has one or more wires broken, or just possibly a bad connection where the cable connects to the mbd. If you have the expertise to disassemble and repair, those cables are available at many places like Fry's Electronics, however many are soldered in place and require quite a bit of technical expertise to replace. I would suggest doing some price shopping at some of your local repair shops.Here is what the manual says: Problem
Action
The display panel is blank when the system is turned on
  • Make sure the TransPort T1200 is not in the Standby or Hibernate suspend modes. The display is turned off to conserve energy in these modes.
The screen is difficult to read
  • The display resolution should at least be set to at least1024x768 for optimal viewing.
  1. Go to [Start > Settings > Control Panel] and double-click the Display icon.
  2. Under the Settings page, set screen resolution to at least 1024x768 and choose at least 256 colors.
The screen flickers
It is normal if the display flickers a few times during shutting down or powering up.
Nothing appears on the screen.
  • During operation, the screen may automatically turn off as a result of power management. Press any key to see if the screen comes back.
  • The brightness level might be too low. Increase brightness by pressing [Fn+F7].
  • The display output might be set to an external device. To switch the display back to the LCD, press [Fn+F5], or change the display through the settings in Display Properties.
The characters on the screen are dim.
Adjust the brightness and/or contrast.
Mar 11, 2009 | MPC Computers TransPort T1200 Notebook
JoWood Productions Transport Giant Gold Edition for Windows Logo
189 people viewed this question
Top JoWood Productions Video Game Consoles & Games Experts
James Wishart
andrewcahoon
Carlos L. Burgos
Carlos L. Burgos
Are you a JoWood Productions Video Game Console and Game Expert? Answer questions, earn points and help others
