Question about Maytag MES5770 Electric Kitchen Range
I have a Frigidaire electric range and the display is gradually fading away. The rest of the range (stove top and oven itself) is in good shape so I don't like the thought of replacing it. Repairman said that the whole board needed to be replaced at great expense. I can manage with the almost impossible to read display but want to know if the whole oven will be useless when the dispay actually quits.
huuum
  • 750 Answers
SOURCE: when I try to bake
Hello wittjabel,
Welcome to Fixya
Please send me the model number and year of your range.
You could try turning off the breaker to the range for 5 minutes and see if this resets the system!
Let me know.
Thank You, I'm waiting.
Please remember to leave a rating before you leave.
Huuum
Posted on Oct 03, 2008
jsrock516
  • 5911 Answers
SOURCE: i tried to change time on range but now reads 5Ab.
You may have inadvertently set your range to "Sabbath Mode". The display actually reads "SAB". This is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
To turn the Sabbath Mode on/off for the Maytag model you have listed, you simply press and hold the "Clock" button for 5 seconds. These instructions should be in your owner's manual.
If these instructions do not work for you, or if your model number is different than what you posted this question under, please post back with your correct information. I hope this helps you.
Posted on Nov 05, 2009
SOURCE: I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Posted on Jan 26, 2010
jumptrout51
  • 3361 Answers
SOURCE: Digital read-out no longer works.
You must replace the oven control. There is no reset.
Posted on Jul 17, 2011
richroth
  • 9472 Answers
SOURCE: Maytag electric range MER5765RAW1 stove and oven
The control board has gone out on the unit. You can access it by removing the screws on the back of the console panel. You will need to replace the control board with this part.
Posted on Aug 13, 2011
Frigidaire electric range model FEF379ACJ Does not work
You will need to replace the main control board/clock, on the unit. It controls everything on the unit. Here is the part to order.
Dec 01, 2012 | Kitchen Ranges
How to replace a glass top on my stove?
To lift up cooktop open oven door. Remove 3-4 screws securing cooktop to top of oven. lift up. Top hinges back. The rest is plain to see. Good luck. Will help futher if needed.
Mar 30, 2011 | Frigidaire FEF366 Electric Kitchen Range
My PLEFMZ99GC is showing an
Please read this article... it appears our model is under recall by Fridgidaire. You should probably contact the manufacturer right away to see what should be done...
http://www.appliance.net/2009/recallfrigidaire-and-kenmore-smoothtop-electric-ranges-due-to-fire-hazard-1369
Oct 25, 2009 | Frigidaire PLEFMZ99GC Electric Range
Frigidaire range blew up
It sound like something shorcircuited and put WAAAAY more current through your oven than it can handle.
You could test the circuitbreaker's circuit by pluging something else in that circuit (a 2kw appliance would be an appropriate test).
It's hard to say for sure but with a fault like that if it wasn't from the oven itself your circuit board should show a visible sign of overcurrent.
I would suggest trying to get something out of the Frigidaire, talking to the retailer if he can do anything and if no one gives contact a consumer reports journal. They love dirt like this.
Frankly, this fault, if it is oven related is dangerous and all appliances should be 'intrinsically safe.'
Good luck.
May 10, 2009 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Sep 17, 2008 | Frigidaire FGFB75D Gas Kitchen Range
Oven's digital temp display too dim to read
The electronic control board will have to be replaced
Jun 07, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Dec 13, 2007 | Frigidaire FES367 Electric Kitchen Range
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Open Questions:
See all Maytag MES5770 Electric Kitchen Range Questions
Maytag MES5770 Electric Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
