Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Having constant issue with paper jamming...all paper types. Can't get even one page printed without jamming for months. Finally gave up and now I really need this machine working. Can't find anyone to service it within 50 or more miles. It also started sucking down toner (literally a new Canon ink per month with regular everyday printing. My husband did empty that toner overflow bottle thing opposed to replacing it...could that be the issue with the machine using so much ink/toner?
  • 54 Answers
YES. ALSO YOU COULD SET THE PRINTER ON ECONOMICAL MODE.....
Posted on Mar 26, 2011
Pick up roller rotates twice even if when gives single page print command and creates paper jam.
I do not know for sure on the Samsung but on HP's this problem is often caused by the pickup solenoid sticking. There is usually a foam bumper on the pickup solenoid which breaks down over time and then the adhesive stops the solenoid from releasing properly. You can clean it off all the old foam and adhesive and run without it, just make printer a little noisier. The solenoid will usually be on the right side.
Aug 30, 2016 | Samsung Ml-1675 Laser Printer 17ppm...
Paper jamming
Try disconnecting for a while and see if it resets.
Jun 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
My Dell 1720dn constantly has paper jams. A
I am having the same problem, did this get resolved?
Dec 02, 2009 | Dell 1720dn Laser Printer
Canon Imageclass MF4370dn constant paper jam errors
Dear
Inside the back panel there are paper sensors attached to lever, a small spring connected to lever to keep its home position, the spring may dislocated from its position or the lever sticked to the base. some times a small piece of paper sticked at this may cause the problem.
Thanks.
Apr 20, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Paper jam, no printing, constant error
you can Visit the Konica Printer Knowledge base, which explains on a .pdf and with a video, how to clear the basic fuser roller jam with a piece of card.,no printing,etc click the link and put in your product type that wil take to faq page youll see the issue and solution elaborated
http://crm01.konicaminoltaeurope.com/openmind/technic/engineer/qmspubkb.nsf/start
and work your way through the links.hope this helps
Oct 02, 2008 | Konica Minolta magicolor 2400 Laser...
PAPER JAMS CONSTANTLY
Well, it might be theres something stuck in there. Pick it up and give it a few shakes. I work on printers, and not too long ago I found a wedding ring, paperclip, banana sticker and other things in printers. If that doesn't work, try going to staples and getting a laser cleaner kit. They're basically sheets coated to pick up any paper dust, or bits of paper that might be clogging the path
Mar 11, 2008 | Brother HL-2070N Laser Printer
Paper misfeed
Try to clean the Paper Feed Sensor
Dec 15, 2007 | Epson Stylus Pro 4800 InkJet Printer
Paper light constantly flashes
That flashing paper light indicates a few things on these, most often it is related to paper not in tray or jammed/not picked up but I see in you case it isn't.......
Your light can also be indicating that the page size sent, it doesn't think it has so it is asking you to feed correct size paper as per document that you sent it, into the little slot at the front called the bypass...(change paper size setting in tray or document page size).
You can test if above is problem by unplugging USB turn off/on machine should come to green, press go button 5times supersuper fast, test print should print shortly.
If printing labels, card, transparencys or have setting as this paper type machine will default to manual pass (cause it needs to be feed those sort of things, straight, not from cassette.
It can also mean memory full or print overload, (pressing go button will start print of remaing data) Doc too complex
or Door open front or back
or even Clean Carona (blue slidy thing on drum)
Drum light fix below
Open cover
Press and hold down Go button for about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the Go button
Close cover
link to MANUAL
Nov 19, 2007 | Brother HL-2070N Laser Printer
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
128 people viewed this question
old marine
old marine
