Video clips start and stop and so on - Computers & Internet
How do I pause while recording? I can pause while playing back but can't seem to figure out how to pause a recording then resume, it just stops and starts a new clip. Please help. (My handycam is cano
The default is to start a new clip every time you press the stop button, but in settings you might be able to tell the camera to continue with the same clip provided you press record again with a set time. Not sure why you want to do this though - it's much easier to edit using small clips than very large ones.
Aug 23, 2014 | Canon FS100 Flash Media Camcorder
Pause your video
There is no pause function.
You pause the same way they do it in Hollywood. Stop the current clip, start a new one when ready, then splice the clips together in editing.
Dec 05, 2013 | Sony Cyber-Shot DSC-W560 Digital Camera
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
When watching a video clip, the video starts then stops and does that the whole clip. What can i do to fix that so I can watch the clip from start to finish without it stopping to buffer?
are you watching video clip on the internet? if YES check your internet connection.. if NO try downloading VLC player it is totaly free and works better than your ordinary media player.. have a nice day ahead
Apr 29, 2011 | Computers & Internet
Everytime I play video clips on YouTube I keep having buffering problems like play then stop then play then stop then play then stop continuously.
Once the page has loaded and the video is starting to play, pause the video and let it load completely before playing. The problem is either youtube and some specific videos and/or you have a slow connection and are having difficulties with streaming content.
Feb 27, 2011 | Toshiba Satellite Pro L300 Notebook
Stop/start buffering problems when watching video clips online
no it is because of your internet speed...hope you willsucceed...
Nov 23, 2009 | Microsoft Windows Media Player
Dr hd 100 quicktime clips
You cannot have one continous clip, the clips are recorded seperately
Dec 30, 2008 | JVC DR-HD100 (DRHD10040)
I RECEIVED AN E-MAIL TYPLE PERRY IT HAD A VIDEO CLIP WHEN I TRIED TO PLAY IT. It would play and stop play and stop every time i try to play a video it does what is the problem I BOUGHT THIS COMPUTER...
I wonder if you're having an issue with just this specific video clip or all video clips? If it's just one video clip then I suspect htat it's a file corruption with this one clip. Have the person who sent it to you resend.
Jul 16, 2008 | HP Computers & Internet
Can't turn on my camera!
Hi..
I have a link and some information I found on the video option to your camera. This link is for the manual located on hp.com:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=371583&lang=en&cc=us&lc=en&dlc=en&
The following is how to stop video:
To stop recording video, press and release the Video
button again; otherwise, the video will continue recording
until the camera runs out of memory.
NOTE
If you have set the camera to Self-Timer or Self-Timer -
2 Shots (see Using the Self-Timer Settings on page 44),
the camera will start recording 10 seconds after you press
the Video button. However, with the Self-Timer - 2 Shots
setting, the camera only records one video clip.
After recording has stopped, the first frame of the video clip
appears on the Image Display. While it is processing, you can
delete the video clip by pressing the Menu/OK button
Good luck and please let me know if there is anything else i can hep you with--feedback would be geat.. thanks, d
Feb 27, 2008 | HP Photosmart R707 Digital Camera
Computers & Internet Logo
David Payne
David Payne
