Question about HP Photosmart C5280 Printer
How can I obtain accurate black and white from my H.P.PhotosmartC5280 printer? I get colour casts of sepia, blue or magenta, even when I remove all colour in Photoshop Elements 6. I know several ways of converting to black and white but none print out accurately.
  • 54 Answers
Then select, "Paper Type/ Quality."
Then under Paper> Color: select "Grayscale."
Posted on Mar 26, 2011
My printer prints in green not other colours
Most printers have 4 color inks: Black, magenta, cyan, yellow.
If your magenta ink isn't printing, then your prints will have a green cast.
If your printer has a "nozzle test", I suggest doing that. If it has a "head clean" function, that may help.
Replacing the magenta ink cart may be all that's needed.
Jun 20, 2015 | Office Equipment & Supplies
My black and white photos will only print out in sepia. I have plenty of ink in the Cartridges of my MP610. Please help?
Two possibilities come to mind:
  1. There is a function in many printers that lets you print in the single colour of your choice. Check every tab and every "advanced..." dialog box you get when you are about to print. Then go to the printer's properties in the control panel and check whether there's anything like that
  2. Many printers let you print black with black ink, OR alternatively make black by mixing the other three colours CMY. Look for that setting in the same places and deactivate it
Feb 27, 2013 | Canon MP610 Photo All-In-One Printer
Canon pixma ip3600 blue colour cast
I don't get true B&W but only 1/2 a Gnats knacker off it, if you send for a test print from say Ilford you'll notice that it's not B&W but a warm tone very slightly sepia.
I use cheapo inks bought on eBay so none of the settings in software are of any use. I disable any attempt by the software to influence the printer and do the same in the printer settings window. I then alter the colours using the sliders in the Manual section of the colour/intensity to the colour that I see on my screen and save the setting in the profiles section.
I use the iP3600 and have found it very good indeed, after lots of experiments I've settled on a sepia tone reminiscent of Sodium Sulphide but without the nasty smell.
Jim
Jun 23, 2012 | Office Equipment & Supplies
After changing the toner cartridge of an HP3600 the printer calibrated but then has started printing in a Sepia type colour and not giving a true colours
Any chance you just changed the magenta cartridge? Your problem sounds like a defective cartridge, which happens often if you are using a refilled or remanufactured unit. From the front control panel you can go to troubleshooting menu and then pq troubleshooting to print a set of pages that consists of"
1 page of each color cartridge
1 white page
1 configurationpage
1 page that tells you how to use the pq troubleshooting pages
If the sepia problem is accross all of these pages then if most likley is the magenta cartridge that is bad. If it is only one page that is bad the color that is bad will be the bad cartridge.
Mar 28, 2011 | Office Equipment & Supplies
What does it mean when it says change k cartridge
There should be four ink cartridges inside the printer: Cyan, Magenta, Yellow and blacK.
While monitors build colours out of three emissive (active) base colours, red, green and blue, printers usually build them out of four absorbing (passive) inks, so-called CMYK. The black is referred to by its last letter to avoid confusion with Blue.
On most printers, since they usually print in black ink over white paper (and black is used to darken all other colours), the K cartridge is either bigger than the others, or needs to be replaced more often.
Mar 31, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
Epson cx3200 wrong colour
It is possible that when the printer senses not enough black ink it will swap to using the colour tanks to try and make a BLACK.
It is also possible that you have mistakenly adjusted a setting in the epson printer program to use the colour tanks to print black and white photographs.
Either of those would certainly cause the problem you describe
Check ALL your printer settings both the windows ones AND your epson ones
If you found this information useful pleas click below
Aug 12, 2009 | Epson Office Equipment & Supplies
Epson R265 printing colours incorrectly
For the black and white issue, check the settings and make sure that it isn't set on "sepia". As for the color issue, it is quite possible that you are out of ink. Printers may use more of one color than another depending on what you're printing. Change your color cartridge.
Jul 02, 2017 | Epson Stylus R265 InkJet Photo Printer
OKI C5100 alignment issues, I think
FROM YOUR USEWR MANUAL>>>>>>>
In colour menu
AJUST REGISTRATION, press EXECUTE
Performs automatic colour registration
adjustment. Normally this is done on power
on and when the top cover is opened and
then closed. This process accurately aligns
the cyan, magenta and yellow images to the
black image.
Use oki drums and toners, clean led heads
Dec 19, 2008 | OKI C5100n Laser Printer
Canon Pixma 4500 when printing on photo paper there is a Magenta cast over the print, even on black and white prints
the Magenta ink cartridge is leaking. replace with a new one.
clean the ink cradle before insert eh new one.
Nov 12, 2008 | Canon Office Equipment & Supplies
HP Photosmart C5280 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
