Question about Sony Playstation 3 (PS3) Console
Have sony ps3 sharp lc-32bs28ut-a tv and I live IHH810B home Theater sys. HTS works when using sat sys. but wont work through ps3and tv when watching movie contact sony sharp and ilive could not get to work together any suggestions?
How to connect a Panasonic SA PT950 home theater syst. to a Samsung flat TV UN65JU650D?
Samsung 40'' 720p tv and Panasonic home theatre system ...
? 5:30
https://www.youtube.com/watch?v=zDG-PZtqCNE
Jan 4, 2012 - Uploaded by Nazil Rahman
Samsung 40'' 720p tv and Panasonic home theatre system ...How to Connect an HDTV to Your Sound ...
New way to connect TV to Surround sound using HDMI ARC ...
? 4:46
https://www.youtube.com/watch?v=fFNEKnlQd6I
Dec 13, 2013 - Uploaded by Tampatec
How to Connect TV to Surround sound receiver system setupusing HDMI ... to Samsung, LG, Sony, Vizio ...
Unable to connect Samsung smart TV with Panasonic home ...
www.tomsguide.com/.../unable-connect-samsung-smart-panasonic-home...
Dec 16, 2014 - hi I bought Panasonic SC-BTT405 blue ray disk 5.1 home theater and ... Unable to connect Samsung smart TV with Panasonic home theater ... I have an LG55LA9650 smart TV hooked up to a Bose 3-2-1 home theater system.
Jan 23, 2016 | Samsung Audio Players & Recorders
How do I connect the Home Theatre System so that I can hear surround sound from the TV instead of through the TV speakers?
watch this ......copy the below item and paste it on google ....there it will show you the whole video...it will solv your problem
Nov 20, 2015 | Sony DAV-SR2 System
I have a denon avr-x2000 all hdmi ports except the cab/sat are fuzzy. it started with the PS3 on the game port
Plug your ps3 and/or blu-ray directly into the TV and see what it looks like. use different HDMI cables to test them. Once you know that all works then setup your avr-x2000. Does the Denon menus look fuzzy?
Mar 20, 2014 | Denon AVR-X2000 In-Command 7.1 Channel 4K...
How do I get tv audio to play on the home theater system
This HTS isn't really designed to be a versatile processing center for external sources.
My advice is to treat TV-related audio as any other audio component. First, its best source will be the first device that processes it - cable box, sat box, gamebox, BD etc.
I'd also bypass this unit's video connections for those video sources and run them directly to your TV or monitor. The best unit for each function (audio or video) should get the best source directly.
Get the best-quality digital audio that unit will provide and run it into the HTS. This HTS has one optical (TOSLINK) digital input, so THAT would be where the best digital audio would enter it. Hopefully, your source uses optical audio output. Otherwise... analog audio is limited to stereo or derived Dolby Surround.
Sorry.
Dec 23, 2010 | Samsung HTC550 Theater System
Is my tv audio doomed or will the home theatre system work anyways.
some devices these days have a built in volume control, try using your remote for which ever dvd player or satalite bix you use, on push the volume up button on it while you have the volume on the tv maxed out so that you will be able to tell a defference if it works or not.
Jun 02, 2009 | Philips HTS 6600/12 Home Theatre...
Connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Oct 20, 2008 | Sony RDR-GX300 DVD Recorder
I cant hook my PS3 to the surround system for Sony DAV-HDX275W
what exactly is the problem? no connections? or connected and cannot get it to work?
Aug 31, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
How Do I Hook This Thing Up?!?
See what audio outputs your tv has. See if your HTS has matching inputs. If it does connect them with the proper cable(s). Connecting to the tv should cause your HTS to work with anything you are watching on the tv.
May 15, 2008 | Durabrand STS92 System
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
