Question about Honeywell HZ-709 Oil Filled Radiator Heater
Ran out off oil got more trying to plead out the air can't get unit to stay on long enought to get water out of all raditors, how do i keep it on
  • Honeywell Master
  • 43,501 Answers
Here is a tip I wrote about how you can bleed the air out of the lines to get the oil burner working again...
How to Bleed Oil Burner - Beckett Oil Burner Repair
heatman101
Posted on Mar 26, 2011
Our Generac Generator 04675 (15 kW LP) ran for 3 days in a row due to a power outage. It shut off for low oil on the fourth day. We Added 1 qt oil and we restarted it and it ran great for another day...
The only time a battery will blow up is if the hydrogen gas ignites. Usually what happens is that when the battery is being drawn like during cranking, or trying to be recharged at a high rate the battery begins emitting hydrogen gas from the sulfuric acid. This is usually why the battery is kept away from anything that sparks usually. When the hydrogen gas comes out it also slowly bakes off pure water. When this happens and the level drops below the level of the plates in the battery, when the battery has to make amperage during cranking an ark occurs accross the plates igniting the hydrogen gas and making a miniature atom bomb. Loud isn't it?? To prevent this from happening keep an eye on the charge rates of the battery and if the battery has removable vent caps, keep the level topped off with distilled water. Please also note that many residential gensets do not charge their own battery and rely on the maintenance charger to always keep the battery charged. Make sure the maintenance charger is on a circuit that will be powered by the genset during a utility outage.
Jul 16, 2011 | General Electrical Supplies
I have a mpi 2400 monitor. I ran low on fuel so I went and got 4 or 5 gallons to keep it going till my delivery came, but it keeps shutting of and getting an error E 14. I know this means there are...
usually when you run out of oil,you need to bleed off air. there's a bleeder on pump looks like bleeder on a car brake cylinder.atach a piece of rubber hose and run to a bottle, open it up when pump is running till all you get is oil.
Jan 25, 2011 | Heating & Cooling
Why my low coolant light comes on at time. but its not low on coolant. i just put a new water pump on.
CHECK COOLANT OVER FLOW RESERVOIR MAKE SURE IT HAS COOLANT IF YES.YOU COULD HAVE A FAULTY COOLANT LEVEL SENSOR IN THE COOLANT OVERFLOW RESERVOIR. CHECK TO MAKE SURE ELECTRICAL CONNECTOR STILL INTACT.LIGHTLY TAP WITH THE HEAD OF A SCREW DRIVER BELOW COOLANT LOW LEVEL SENSOR BOTTOM OF COOLANT RESERVOIR.IF LOW COOLANT LIGHT GOES OUT COOLANT SENSOR PROBABLY STUCK IF LIGHT STAYS ON COOLANT LOW LEVEL SENSOR BAD.
Sep 01, 2010 | 1999 Pontiac Grand Prix
I have replaced raditor cap and flushed and cleaned coolant overflow tank. I top off overflow tank and raditor and drive for a bit check raditor level and it is down . Some times I add almost a quat of...
could be a head gasket (coolant going into exhaust or into oil) pull oil dipstick does it look light brown like the color of a chcolale milkshake if yes u have bad head gasket does exhaust blow white smoke? if yes bad headgasket ? pull radiitor cap off let van run for while does water come out of raditor at a fast rate if yes (possiable ) bad head gasket
also could have leak your not seing look closely around where intake meets heads notice any water trails or see any water leaking ? if yes bad intake gaskets look closely around water pump any trails of water there ? if so bad water pump also check closely around seams of raditor for water trails
after all this u dont see any thing might need to take it to a shop and have it pressure tested (some leaks will only show up under pressure) most shops won' t charge much if anything for this service
Jun 11, 2010 | 2002 Dodge Grand Caravan
Cleaner is floating on top of pool
First, remove all of the air from the cleaner head and stop all air from entering the pool2_bing.gif through the return lines. Also, if the head and hose are covered with bubbles, give the hose a good tug. This will release the air bubbles and allow the pool cleaner to settle son the bottom of the pool. Also, the cleaner head may actually be being lifted off the bottom of the pool by the hose or the pressure in the return lines. Make sure that the hose stays untangled and the pressure from the return lines is not too low (not enought pressure to power) or too high (too much pressure that cause the unit to lift off the floor).
Apr 20, 2010 | Hayward Navigator Pool Cleaner
My 1998 keeps overheating b/c the fan does not come on. I went to my "new" mechanic and he said that my oil cooler sends water to keep my oil from becoming too hot. He said he found oil in my radiator and...
Ok pull your dip stick out and look for white spots on it. When you get water in your oil it gets milk looking. try it get a cup of used oil or new. and mix a cup of water in it. you can tell and if you got a little oil in your raditor what do you think water pump lube is??? i would go to aldata.com and buy a one year term for my car and stop trusting every auto repair shop read and test for your self. you can do it my sister does all her own auto work.
Aug 08, 2009 | Volkswagen Beetle Cars & Trucks
Thermostat ... i think
at the raditor top hose end-engine side.
Jan 18, 2009 | 1991 GMC C1500
Hot exhaust comming out of the raditor cap
have you flushed out the radiator ? get some radiator flush and flush it out. There could be a blockage in the radiator.
Jul 22, 2008 | 1989 Ford Probe
Honeywell HZ-709 Oil Filled Radiator Heater Logo
178 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
