Question about Samsung Televison & Video
I don't know what's wrong with my TV when I turn on I have to wait for a while befor It's come on?
  • 68 Answers
Elektrolyt capacitors on the power saply board
Posted on Mar 26, 2011
Why does my LG tv seems like it need to warm up before it will accept HDMI signal?
Sounds like a capacitor fault. They can be intermittent when cold, but will work okay when warm. Eventually though they will fail.
This is your advance notice to get the set either repaired by the manufacturer or a local TV shop.
Sep 06, 2014 | LG 42LG50 42 in. LCD HDTV
Tv will not turn on
Check the obvious first Power to the tv ok?
So many things can go wrong with tv
power switch
start switch
stand buy power unit
fuse in tv
component blown
etc, etcetera,.......
If you don't know tvs
only choice is the shop Hope it is still under warranty
Feb 06, 2012 | Sylvania Televison & Video
My Element 40" Tv is stuck in stand by how do I
hi have you changed the batteries in the remote, if the remote is ok there's a fault with the tv, could be a swollen capacitors shorted diode or poor solder joint,or a bad mainboard , thanks
shaun
Mar 08, 2017 | Element ELCHW402 40 in. LCD HDTV
I was given this model tv. The green and red lights on the front are flashing. Says to replace bulb and close lamp cover correctly. I am missing the lamp cover. Is that going to be a problem?
U mean the Lamp door cover?Yes?Tv might work,might not.Don't know never tries to turn the tv on before without a Lamp door cover close before.There is a blue safety switch though must be press down when the Lamp door cover is close.Test it out.Why don't u just take a piece of tape and tape that blue safety switch down tightly,than turn on the tv.If the tv message that said close lamp cover correctly disappear.Than yes the tv will work,without the lamp cover closed.Now u just needed to do a replacement of the tv projection lamp only that all.
Sep 24, 2011 | Toshiba 62HM95 62" HDTV
I pushed the wrong button on my remote and now my Akai flatscreen says no signal. But I don't know what button I pushed! Please help!
Unplug TV from power outlet ,wait 5 min and pluged back.Should go back to manufacture setup
Cheers
Aug 23, 2011 | Televison & Video
I have a Husky air compressor model WL651004AJ. The problem is that it builds pressure initially up to 75 psi then shuts off. I have to turn off the power switch, wait about 5 minutes, turn the switch back...
It sounds like you need to replace the run capacitor , if yours is weak or defective the motor will overheat. Check "Drillspot" for a replacement. Another major cause of overheating is due to a dirty air filter , you should check it first.
Don F
Aug 12, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
The New TV.don't come on, keep showing no signal, don't know what is wrong, can you help us, to get it going. thank you
The TV is turned on. The TV showing "no signal" is an indication that is turned on. Its just that the TV is not recieving any signal whatsoever from an antenna, DVD player or dish.
I suggest you connect thee TV to a DVD player. Click source on the TV remote to AV 1. Use a RCA (yellow white and red wire) for the connection.
Yellow stands for video and white and red stands for audio. Connect yellow to "vidoe out' from the DVD player to 'video in' at the back of the TV. Do the same for the audio white and red.
Now there should be a display on the TV. If there is not display, check your connection.
Let me know if need more help.
Your sincerely.
Elect_Comp.
May 13, 2011 | Televison & Video
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
The check engine light will not go off and not one shop can find anything wrong with the car.
Reset your ecm. Do this by turning your key to on position with a/c on " engine not running" then disconnect positive battery terminal wait 30 sec. and reconnect, Should clear out all codes from ecm. If this don't work may have to go put on the computer to diagnose problem. But i think this will help. Good luck and let me know how it go's.
Mar 23, 2011 | 2000 Aston Martin DB9
Televison & Video Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
