Question about Coby MP-610 MP3 Player
I have purchased a bush MP3 player MPK8099BUK and when the device is connected to a USB port I am unable to use the menu screen. It reads "connected Eject before disconnecting" The reason I bought the player was to use with my usb compatible car radio installed on my boat. when plugged in to the radio I then want to choose the tunes from the mp3 list. the songs start to play through the radio and are identified on the radio digital read out. This means I can hear them but not select the tunes I want. Hope this makes sense. The same message reads when connected to the computer.
  • 3 Answers
Press m.
Posted on Apr 09, 2012
    Problem Solver:
Hi don`t know if u have sorted your player yet but the pc has to be rebooted to have it charging and to be able to play the player hope this is of some help. Paul.
Posted on Jul 23, 2011
Ive got that same mp3 aswell...
while the mp3 is plugged into something like the computer,
you wont be able to go onto the menu as it will start charging straight
away!!!
hope my comment helped.
Posted on Aug 13, 2011
  • Vanessa Jones Aug 13, 2011
    f u LFC2458 U DNT MAKE SENCE!!!
My bush mpk8099buk don't play video
I have a bush mpk8099buk and i had this problem it all depends on the file type i found that if i downloaded the videos as a 3gp file and then put it in the video file the video played with sound and picture this is the converter that i use YOUR ONLINE VIDEO CONVERTER
Apr 08, 2013 | Audio Players & Recorders
How to unfreeze coby mp600
Hello
Download the firmware update and save it to a location on your hard drive that you will be able to remember. This firmware includes a specific fix for the multiple reasons that the device is freezing.
Press and hold the "Menu" button on the player, then connect the Coby to your computer's USB port. The power on the MP3 player must be turned off when completing this step. If your MP3 is frozen, unable to be powered down, use the push pin to push the "Reset" button on the bottom of the device.
Let go of the "Menu" button on the player once the "Found New Hardware" screen appears. When asked if Windows can connect to Windows Update to perform a search for the necessary software, click "Yes, this time only," then click the "Next" button.
Choose "Install from a list or specific location(advanced)" to determine where Windows should look for the driver files, then click on the "Next" button.
Place a check mark in the box labeled "Include this location in the search," then click "Browse." You can search for the directory location where you saved the driver file in Step 1. Double-click the driver package and select the "usb_driver" sub folder as the driver location. Click "OK," then "Next."
Select the "m3usb" file from the "usb_driver" folder when prompted on the next screen, then click "Open" and "OK." The "Completing New Found Hardware" screen will appear once the drivers have been successfully installed, then press "Finish."
Unplug the Coby MP3 player from your computer.
Double-click the "USB tool" EXE that is located in the "MP3 Firmware Update" folder that you downloaded in Step 1. The USB Tool application's welcome screen appears on your computer.
Press the "Menu" button on the Coby MP3, holding it down as you reconnect it to your computer. Your MP3 is now identified as "Device 0" within the USB Tool, and you have a yellow-colored status box when connected.
Click "Burn NAND" to begin the firmware correction process. After about four or five minutes, you receive a notification saying, "Burn Task Completed."
Disconnect the MP3 player from your computer, and wait for the device to power up completely.
Click the next series of green boxes that have red lines going through them on the screen with your finger or a stylus until the menu appears. You see them in the top-right and lower-left corners of the MP3's screen as calibration on the device is being completed. The firmware is now installed.
Sep 29, 2011 | Coby MP-610 MP3 Player
How do I shuffle songs on my Bush MPK8099BUK MP3 player?
If you set the play mode to shuffle. It should shuffle whatever you are playing, be it All Music, An album or a playlist.
you can set the player to shuffle by pressing the "M" button. from the menu choose "Repeat" mode press "Previous/Next" to scroll through the options until you get to "shuffle". [Press "Play/Pause" to confirm and press M to return to sub menu.
Aug 04, 2011 | Audio Players & Recorders
My transcend Ipod is not getting detected in the computer
Hi, when an pm3player does not detect on your PC, usually when Drivers that corrupted..
How to rectify the problem:
Connect the mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 player Connect and mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for mp3 Players when used with Windows OS.
The mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Good luck to you.
Feb 25, 2011 | Transcend T-Sonic 840 MP3 Player
My pc window can not recognize mp3 player
Hello
Connect your Sansa MP3 player to more than one USB port on your computer. Ensure that your computer USB port is not corrupt or disabled by testing at least two available ports. This is especially useful when you possess no other USB-based equipment.
Inspect your USB ports' status to ensure they are enabled on your computer. Right-click "My Computer" and launch "Properties" to verify the availability of such connections. Select "Device Manager" from the Hardware tab and click the "Universal Serial Bus Controllers" from the list shown. If a red "X" is shown, the USB ports are disabled.
Ensure your computer is updated by clicking "Start" and launching "Windows Update" from the Programs menu. Alternatively, inspect your USB port connectivity through your motherboard BIOS settings. Note that BIOS access and settings varies by mother board manufacturer.
Scan your computer for new hardware changes. From the Device manager, click the "Action" menu and select "Scan for hardware changes" while your Sansa MP3 player is connected. Allow your computer to attempt to find any physical component recently added in the event it failed to previously detect it.
Connect your Sansa player to a different computer. Test the connection on a different system's USB port to verify that the Sansa device's own connection has not been damaged. Inspect the USB ports on the computer in question as well to eliminate the possibility of both systems having problematic USB ports.
Change your Sansa MP3 player's USB plug. Sometimes the head of the plug may lose contact with the appropriate circuits. Obtain a secondary USB port at your local retail store and test it on an updated computer system.
Nov 14, 2010 | SanDisk Sansa e250 MP3 Player
My computer is not reading it
hello
Inspect your USB ports' status to ensure they are enabled on your computer. Right-click "My Computer" and launch "Properties" to verify the availability of such connections. Select "Device Manager" from the Hardware tab and click the "Universal Serial Bus Controllers" from the list shown. If a red "X" is shown, the USB ports are disabled. Ensure your computer is updated by clicking "Start" and launching "Windows Update" from the Programs menu. Alternatively, inspect your USB port connectivity through your motherboard BIOS settings. Note that BIOS access and settings varies by mother board manufacturer.
Oct 01, 2010 | SanDisk Sansa m240 MP3 Player
Sansa Fuze, 8GB, unable to be turned on in the car after playing it just a short while ago, and is unable to connect to computer; screen is white.
You may need to now reset the player, that may have been a bit much for it. To reset your Sansa Mp3 player. Slide and hold the Power switch up for approximately 20 seconds. Release the Power switch. To turn the player on, slide the Power switch up then release instantly. If that does not get your player working again, try and Format to clear any corrupt files that may be present.
http://www.fixya.com/support/r3962743-sansa_mp3_player_frozen_reset_format
-Also try to refresh the driver in your PC. Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. >>>><<<Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
I'm having trouble charging my mp3 it won't stay connected how do i fix that?
Refresh the driver
Connect the player to your computer.
- If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working.
<<<<< BUT TRY THIS FIRST >>>>>
Check the Device Manager
1. Right-click My Computer, and select -- > Manage.
*** See This Tip Posted here ****
Solve your MP3 Player Connection Problem.
Refresh the drivers
>>>> BUT TRY THIS <<<<<<<
Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Feb 22, 2010 | SanDisk Sansa Clip MP3 Player
NS-xV24 Insigna Pilot
1) Hold the power button (slider) in the on position for about 15-20 seconds to force the player to turn off, if it's already on.
2) Hold the menu button down and simultaneously hold the power button (slider) to the on position.
3) Do not let go when the device turns on. You will then get a screen message in black and white that reads (with a typo):
WARRING !!!
NAND FLASH MEMORY INITIALIZE......
"WARRING !!!" will appear in red (and probably should read "WARNING". You will have the options of "No" and "Yes".
4) Choose "Yes" to re-format your device.
Jun 24, 2008 | Insignia Pilot MP3 Player
IPod Shuffle and compatibility with USB ports
yes it's a common problem, it might be a usb 2.0 or high speed usb port but the motherboard is unable to supply enough ampage to supply the port. Assuming you have tried removing other usb connected peripherals and tried a different port, the only way you may get the ipod to connect is to purchase a mains powered usb hub as the power supplied is sufficient to connect to ipods and pda's etc.
Sep 10, 2007 | Apple iPod shuffle MP3 Player
Coby MP-610  MP3 Player Logo
2,646 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
