Question about HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply
Green light flashes on the back of my HP Pavilion 1270 when I connect the power cable but the desktop doesn't start up ( totally dead) . I assume it is the power supply , so I can buy a new one, but how can I be sure that's the problem ? kind regards Bart
  • 202 Answers
It sounds like the power has failed or is failing. This link will take you to the HP site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN#bph06788_section_2
You can try to un-plug the main power connection to the motherboard and then re-connect it. BE SURE THAT THE COMPUTER POWER CORD IS DISCONNECTED! If that fails, you will need to replace the power supply as indicated on the HP site. The last one I bought was about $35.00.
Good luck and please let me know how it works out for you.
~Spoem
Posted on Mar 26, 2011
Testimonial: "thankx Spoem, after posting this cry for help I searched the same site and found the same answer. Tomorrow to the store to buy a new power supply!"
Green power supply light is flashing so power is getting to the computer, however the computer will not start from start button. Have removed case and tried ***** start button. Didn't work. Comput
Power getting to the computer/Power Supply?
Yeah.
Power Supply good? -> NO
A) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
HP Pavilion a810n Desktop PC?
Uses an AMD Athlon 64 3300+ processor,
(Operates Up To a frequency rate of 2.4GHz)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00280647
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_microprocessors#.22Newcastle.22_.28CG.2C_130_nm.29
Can use up to 89 Watts of power.
Your Power Supply doesn't even have enough power to spin fans, much less start the Processor.
Want to test the Power Supply? Have a multimeter?
No? Have a power supply you can borrow for a test unit?
KNOWN to be good, and Compatible?
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 05, 2012 | HP Computers & Internet
My HP desktop computer wont turn on, green light flashing in the back?
The green light flashing may indicate a damaged power source .. I suggest to check it or use another one just to see if the system boots up ..and after that order a new one only after you are sure this is the cause....when it plays dead .. the causes can be from the cpu .. or the cpu fan not working and this will keep it from boot .. or the motherboard itself .. even the ram memory must be checked but usually it starts and restarts in a loop when the ram is faulty .. and in other cases may have an amber light on the board.. so ..if there is no power the cause it is probably most likely the power source
Jan 24, 2012 | HP Pavilion a1410n (ER890AA) PC Desktop
I am unable to start my HP pavilion dz6700 laptop..it turns on and in a sec it switches off. Battery of laptop is dead and even though i connect to externa power source it doesn't start
Unfortunately there's a problem with the motherboard of the laptop, you need to replace it. One of the circuits is grounded or is totally dead to accept and release power for the unit to turn on.
Hope this helps.
Jun 13, 2011 | HP Computers & Internet
Hello, my HP Pavilion desktop PC m9177c went dead after a power outage. Right before the outage, it was on and connected to a surge protector. After the outage, it is completely dead as if there is no...
You may have to change its power supply however, try this first
1. change your UPS coz the old one may have been damaged.
if that still didn't work, change your power supply
Nov 28, 2010 | HP Pavilion a710n (PJ508AA) PC Desktop
Computer wont start just a green flashing light at back desktop hp 760
check your cable coming from plug to pc, and check the power supply box of your pc, one out of them will be faulty because current is not coming to your computer thats y no activity or sound is coming
Sep 12, 2010 | HP Pavilion 760n (P6320A) PC Desktop
Bestec model atx 250 12z flashes green when hp pavilion a706n is powered on light on back blinks green and pc does not power on even after all cables are disconnected
Try these suggestions:
<a href="http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&cc=us&lc=en&dlc=en&product=427167&dlc=en&lang=en#bph06788_section_2" >Troubleshooting Power Supply Issues</a>
Nov 29, 2009 | HP Pavilion a706n PC Desktop
HP Pavilion A520N will not power up. Green light
Which light?? the network light?? Do you get anything when you press the power button if not it is most likely the power supply since the motherborad is still showing power also may be cpu!
Nov 17, 2009 | HP Pavilion A520n (DW233A#ABA) PC Desktop
I got hp pavilion pc the problem is its not switching on there is a green light back of the pc it keep flashing what i ve to do My HP Pavillion will not come on and the green light at the back keeps...
if your network cable is plugged in it will flash green .....if it won't turn on pull the plug and wait 10 seconds or more then plug in again and see if it will start .....are the fans running and no signal to monitor?
Jan 06, 2009 | HP Media Center m1180n PC Desktop
Medion notebook pink will not start up
Take the battery out disconnect the power cable then press and hold the power button about 7 seconds. After that but the battery in connect the power and turn it on. It will work if the issue static lock up. If you need further assistance please post.
Good Luck
Nov 09, 2008 | HP Pavilion dv6000z Notebook
HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply Logo
632 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
