How old is GE Washer G-136-0? - Washing Machines
What is error code 136 on a fisher & paykel IW709AU top load washer
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
May 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Whats error code 136
136 is 'motor stall' error and could be anything from a jammed inner bowl to a broken wire or a faulty motor controller board...Probably best to call a tech. because there are a number of components which need to be checked before board replacement....Good luck....Nomess
May 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
How old is my washer? When were these made?
You need a serial number to tell for sure.
They probably stopped making those a few years ago.
And the oldest one I've seen it about 10 years old. So probably between 2-10 years old.
GE washer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | GE WJSE4150B Top Load Washer
GE G-136-0 won't agitate
Either you solved this prob or not but the solution is the lid closure safety switch (the white thing in the oblong whole located at 2 o'clock on the rim of the top as you look into the washer from the top down into the tub.
The mechanism of the switch is poorly designed and breaks free causing the switch not to operate properly.
You need to lift lid (there are 4 bar spring catches front and back holding entire top of washer - thin metal to puch them in and gently lift each cormer then lift topfrom front like it is on hinges in back). I used a nylon wire tie to surround the wire ling close to the white thing and fastened it to the top of the machine with a pop rivit. Works like a charm.
email me if you need to fix it (but you probably have already or thrown it out)
Jan 15, 2010 | GE Washing Machines
I HAVE AN OLD GE WASHING MACHINE AND I CAN'T FIND THE SERIAL NOR MODEL NUMBER WITH THE EXCEPTION THAT UNDER THE LID IT HAS G-136-0 - PLEASE HELP
If your washer has a white plastic tub, look on the back edge as you look over the top of the washer. If your washer has a dark metal tub, try looking on the front lower corner of the left side panel.
May 07, 2009 | Washing Machines
Washer not cleaning grease off dishes
try this most common mistake made is not getting hot water to the washer on the first wash don't care what brand hot water cleans dishes 130-136 best but you have to bring the hot water to the washer before you start it some lines can run a half gallon to the sink before the hot gets there run the water at the faucet till its so hot you cant stand it then start the washer 0 ohms ok
Mar 11, 2009 | GE 24 in. GSD3220Z Built-in Dishwasher
Fisher and paykel intuitive Eco. FAULT 136
blocked pump scoop the water out and remove pump from underneath just clicks out move the white plastic clip
Feb 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
512 people viewed this question
Top Washing Machines Experts
